We are working on a project that will be a long, welded assembly that will be subject to high humidity. Due to the welding requirements, any type of precoated material cannot be used. After fabrication, the assemblies will need some type of protection coating. The assemblies are made with steel pipe, rod, etc, so lots of open spaces where losses would be high with a typical spray process. As well, some areas of the assemblies will be difficult to get coated after it is build.
A dip process is honestly probably the most "ideal" but I am somewhat resistant because then a dip tank need obtained and becomes a very specialized process. There are some similar products in the industry now that are dipped, but sounds like health and wellness are out the window and they basically mix solvents and a paint product in the tank and run with it. I can only imagine the gas off! As well, it is my understanding that process does not leave and very good finish.
Something similar to powder coat might work, but this is a VERY cost sensitive project so any process needs considered on a time/cost/complexity basis. My preference is a water based solution but not sure how practical that really is on steel.
