I was wondering if it would be feasible to create a split sleeve for a metric end mill such that the sleeve's ID = end mill OD, and sleeve's OD = R8 collet ID?
Example: You want to hold a 6mm shank end mill in a 3/8" R8 collet. So you create a sleeve with an ID of 6mm, and OD of 3/8" and then split the sleeve along the Z axis.
Do you think this would work? Thanks!
