Metric roll pins vs English roll pins
Likes Likes:  0
Results 1 to 8 of 8
    Aug 2006
    greensboro,northcarolina
    2,417
    155
    602
    Default Metric roll pins vs English roll pins
    Usually an English roll pin is a few thousandths larger than nominal , but compresses fairly easily to get a press fit into a nominal size hole. I bought 3 mm roll pins from 2 different vendors and they measure 3.5 mm diameter and are next to impossible to get in a 3 mm hole. Is that normal for metric roll pins to be that much larger?
    Aug 2012
    California, Central Coast
    3,938
    2215
    1557
    Chinas QC not up to snuff?
    Nov 2014
    Florida
    4,049
    1611
    1880
    Quote Originally Posted by RJT View Post
    Not sure, but found this. It appears they are slightly bigger than std? 3mm being 3.14-3.25 (.123-.128 so up to .01" over nominal, seems like alot)
    Metric Size Slotted Spring Pins from FASTAR Fasteners | Quality Fasteners
    May 2010
    DENMARK
    3,482
    4039
    12634
    Why 2 different vendors and who were the vendors?
    It'd also be good to know what you specified when you ordered. 2 different vendors getting it wrong?
    3mm is 0.118". 3.5mm is 0.138".
    Sep 2002
    People's Republic
    3,441
    296
    2240
    even a little big for 1/8 roll pins it would seem
    Jun 2012
    Michigan
    4,810
    4414
    2911
    No. You either ordered or received the wrong pin for your application.
    May 2017
    FINLAND
    1,797
    497
    821
    Circlips Australia
    3mm roll pin min diameter 3.3mm and max diameter 3.5mm
    Also says following:
    "ASME is the preferred standard for a number of reasons
    Lower Insertion Force: Smaller diameter to nominal hole ration due to increased wall thickness,
    Higher minimum hardness and minimal slot gap after insertion.
    No Interlocking: Slot gap width is less than the wall thickness which makes them ideal for plating.
    Higher Shear Strength: Due to increased wall thickness, higher hardness and narrow slot."
    In my experience metric roll pins in GM/Saab transmissions are sometimes tight as hell even to remove.
    Coiled spring pins (DIN8750) are more close to size in my experience and dimension tables here say the same:
    http://www.headland-eng.co.uk/Catalo...ensionPins.pdf
    May 2017
    FINLAND
    1,797
    497
    821
    Your table is for the ASME standard mentioned in my previous reply and those indeed seem to be smaller than roll pins to DIN/ISO standard.
    Sooooo... next time OP ask for ASME B18.8.4M
