Metric thread how deep to cut
Likes Likes:  0
Results 1 to 7 of 7
    Aug 2002
    Regina, Canada
    2,331
    5
    71
    Default Metric thread how deep to cut
    Draw tube external thread measures 50mm by 1.5 pitch. Need to make nut to fit. What size hole should I start with and how deep to cut? Thanks Bob
    Jan 2013
    Plainfield, Indiana, USA
    1,714
    1289
    914
    Hole should be 48.5 mm diameter (50 - 1.5), and depth should be all the way thru the nut.
    Jul 2004
    Houston, TX USA
    29,355
    Depth is 0.694 X 1.5. Tool point radius max 0.0633 X 1.5
    (per HTRAL #50)
    Mar 2017
    LATVIA
    279
    72
    148
    formincharcount
    May 2010
    DENMARK
    3,037
    3994
    12664
    Quote Originally Posted by bob View Post
    All you need to know and probably more.
    Sep 2004
    south SF Bay area, California
    1,993
    150
    639
    Do note that the fundamental shapes of the ISO Metric and Unified (aka ISO Inch) threadforms are identical, which allows the same rule-of-thumb for the diameter of the hole to be threaded to be used for both ISO Metric and Unified (ISO Inch) threadforms: "Tap Drill Diameter" = Major Diameter minus Pitch.
    Perhaps obviously, dimensions and tolerances for ISO Metric screwthreads are expressed in millimeters while those for Unified (ISO Inch) screwthreads are expressed in inches . . . AND the Pitch of a Unified (ISO Inch) screwthread will need to be calculated as 1 / Number of Threads Per Inch.
    May 2010
    DENMARK
    3,037
    3994
    12664
    Quote Originally Posted by John Garner View Post
    And more to show what you mean.
    http://f-m-s.dk/1.09.pdf
    http://f-m-s.dk/THREAD%20PITCH%20DIA...CE%20AREAS.pdf
