e: How to ID the PA (pressure angle) and pitch.
First the pitch. English system (inch based) gears are generally specified with the DP. Assuming that you have a sample gear, count the teeth and add two. So if your gear has 20 teeth, 20 + 2 = 22 teeth. Then measure the OD. It is better, more accurate if you have a gear with an even number of teeth for this and also the more teeth, the more accurate your result will be. Now, the DP or Diametral Pitch is the number of teeth per inch of the pitch diameter. This applies to the actual number of teeth and the pitch diameter which is at the middle of the tooth. BUT, standard gears will also have this relationship be true at the OD of the gear if you use the actual number of teeth plus two. That's why I said to add two to the tooth count.
So, divide the tooth count plus two by the OD and you should have the DP. Now if that comes out as a whole number or close to it, then the gear is inch based and you have the pitch.
But if it does not come out even, then you may have a metric gear. Metric gears are specified in Module and that is defined differently than DP. Module is defined as the pitch circle diameter in mm divided by the number of teeth. It is a unit of length and a module 1 gear will have a distance of Pi times 1 mm or 3.141 mm from tooth to tooth along the pitch circle. Mathematically:
M = PitchDiameter in mm / number of teeth.
And the conversion from the English DP to the metric M is as follows:
M = 25.4 / DP
So you can convert the DP number you got above to metric module. One of these two figures should come out close to a whole number and that will tell you what kind of gear you have, English or metric and it's pitch.
Now, the PA or pressure angle. There are two common pressure angles in use, 14.5 and 20 degrees. The best way to determine the pressure angle is to try the mesh of the unknown gear with a known one. But that requires having a known gear of the same pitch and most people do not have an assortment of such known gears.
The visual appearance of these two pressure angles is sufficiently different so that you can tell which one it is by comparing the tooth shape of an unknown gear with the image of known ones with similar tooth counts. Many sources have such images for gears of an intermediate number of teeth and these can be used for a visual comparison.
Greetings all;
First off, I would like to thank you all for participating in the discussion. As some have alluded to, my lathe is indeed in a home shop. This is not a production environment, but rather one where farm and hobby bits and bobs are made. I have virtually no formal training save a couple of semesters of shop class some 40 odd years ago, and a very patient(and talented) son who is a machinist with our Armed Forces.... oh and You-Tube.....
I bought the Standard Modern as an upgrade for a SB9A I have worked on, refurbed, added to and generally really enjoyed because it really wasn't too intimidating. I naively thought the SM 1334 would be a more capable machine. Capable of what, I am not really sure yet, but capable just the same.
One of the things I bought for my SB9A was a set of metric change gears. My son patiently showed me how they were installed, how the process worked, some general pitfalls to watch for and off I went. I even managed to repair some parts on our Disc-bine that saved us a ton of money over buying parts at the dealership.
The SM 1334 did not come with change gears. I don't know how to measure things like DP or PA, in fact I barely even know what they are. I can measure the thickness of the current gears, and I can count teeth. I guess what I am after is a picture of how the change gears are supposed to be mounted (something my manual does not show and something very different from the SB9A), and exactly what gears I should have to produce a moderate array of metric threads. Much of the theoretical discussion above is way beyond my current ability to comprehend. I need it dumb'd down a notch....
Again my thanks to all who have taken the time to contribute to this discussion. I really do appreciate it, and I really do learn a lot from them. You are to be commended.
