Laverda
Cast Iron
- Mar 24, 2014
- Riverside County, CA
I needed to set zero on a new Starrett 10ths reading 3" to 4" micrometer. So I use the supplied standard. I was called away for a few minutes and forgot I had set zero and got another standard that was closer to me (Brown & Sharpe, USA made) and it reads .0002" bigger. I rechecked with the Starrett and it was definitely smaller. So I get a no-name China standard it's also a different length. Finally I used a gauge block and its a little bit smaller than them all.
Now I don't trust the standards at all. So now I have a new $250 micrometer with a standard that may or may not be 3"
The Brown & Sharpe just says 3 on it. Same for the Chine one.
The Starrett standard says nothing.
Mitutoyo says a 3" standard is only accurate to +/- .0001" and one made in China, who knows?
Mitutoyo says the bigger sizes can be +/- .0003" to .0004"
Is everyone else using gauge blocks. I have micrometers that go up to 14" and don't have gauge blocks that big.
