What is a "mill bit"?
I don't do much milling so I have a question about a good cheap mill bit to cut a 1.75 square hole in an encloure that is fabricated from 14 gauge steel. What speeds, feedrate and bit do you recommend? I have an old Bridgeport mill.
You'll need one of them square endmills.
Warning: hard to find.......
We use these all the time:
McMaster-Carr
I'm sure you can rent one from your local rental place.
Fast, easy and safe.
PS: I have a steel cover in my shop right now that I need to mount a digital meter in. I plan to use an 1/8" milling cutter, just as I described above. Some other components will be mounted in round holes so I can do that as well as drilling those round holes all in one set-up on the mill. And everything will fit with NO FILING.
Let the chips fall where they may!
A jigsaw will make quick work of a square hole in 14ga
If you are really allergic to files and still want to mill the opening, you could push a 1/4" square broach through the corners then connect them up on the Bridgeport.everything will fit with NO FILING.
I don't mind a little filing, myself
Notice
