Mill Boring Out of Round?
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Oct 2017
    Michigan
    31
    Default Mill Boring Out of Round?
    My mill is boring .oo15 out of round in almost perfect alignment with X and Y. Long in X narrow in Y
    The mill is CNC, but I am talking about using the spindle with boring head.
    I put tenth indicators on the table to ensure no table movement X or Y
    Machine Head "Z" is also rock solid.
    This problem is repeatable with different materials, setups, boring bars and feeds/speeds.
    No CRASH
    I have never had a mill do this before.
    Any ideas?
    Feb 2007
    St. George, Utah
    1,047
    594
    693
    Spindle bearings? If not the business end, perhaps the top maybe causing a wobble?
    Oct 2017
    Michigan
    31
    I have checked the spindle and it has a tenth or so radial and end play
    Mar 2005
    Kansas
    7,894
    486
    3757
    I presume this is a vertical mill. Your z gib is loose or barreled in the x direction. Use an angle plate and indicator, and align the angle plate with Y. Run the spindle down with an indicator against the angle plate. When you reverse the z axis you should see the indicator jump. Make sure the indicator is similar length to your boring tool.
    For a work around until you can fix it, or hire it fixed, stop the spindle at the bottom of the bore, index the spindle, and retract with the spindle off.
  5. Likes Bobw liked this post
    Jul 2007
    Missoula Mt
    345
    9
    129
    If the head is not trammed to the axis you will bore a egg shaped hole every time....Phil
  7. Likes GregSY, gustafson, Murf liked this post
  8. #6
    Oct 2017
    Michigan
    31
    Thanks guys
    This is a vertical mill with box ways
    I will double check the tram
    I have no way to adjust the Y on the head only the X
    The hole is larger in the X so the tram does make sense
  9. #7
    Sep 2004
    south SF Bay area, California
    2,063
    158
    685
    Spindle "tram" error manifests itself differently when boring as a function of how the feeding is performed, using the quill or using the knee. If quill feed is used, the bore will be generally circular but tilted; if knee feed is used, the bore will be SLIGHTLY elliptical but not tilted.
    Unless your dial gage checking of machine stability reaches from the workpiece to the quill, you probably would be wise to do more testing.
  10. #8
    Oct 2017
    Michigan
    31
    Quote Originally Posted by John Garner View Post
    I am feeding with the entire head
    I will be rechecking the tram later but I know I have a .001 or so out in the Y. This machine has no way to adjust tram in the Y.
    Any thoughts on how to adjust for Y in this situation?
    If my thinking is correct, what ever direction the tram is out should be the narrow/small dimension of the elliptical?
    So if the head is out of tram in the Y axis then this would account for my exact problem. Oval, Small in the Y and large in the X?
    I should mention that the bore I was having a problem with is 1.25 ID by 1.25 deep with .0015 out or round
  11. #9
    Dec 2008
    New York
    10,338
    2681
    Quote Originally Posted by lethal375 View Post
    No CRASH
    Any ideas?
    some cnc have servo oscillation problem and also backlash. (ball screw might need replacing or something loosened up)
    temperature control or changes can easily cause problems too
    once saw a cnc with encoder wheel in contact with side a machine slide to register actual movement. if dirt or chips got between encoder wheel and it wouldnt turn and machine would see no movement, it would command a move till it saw movement. i have seen 0.1" jumps snap end mill off, obviously closed loop feedback when position readout malfunctions it can be a problem, some encoders also get dirty or oily and have trouble reading electronic scale
    if you take a test cut and part moves to side to more easily measure, it might not go back to position exactly when you finish the bore
  12. #10
    Feb 2007
    St. George, Utah
    1,047
    594
    693
    . . .This machine has no way to adjust tram in the Y.
    Any thoughts on how to adjust for Y in this situation?. . .
    If you can adjust in X, there is an interface at the head/ram mounting point. You can usually affect Y/nod by adjusting the tension (torque) of the mounting bolts, the same ones you'd loosen to adjust tilt. It doesn't sound like it would work, but it does.
  13. #11
    Jan 2007
    wales.uk
    1,194
    131
    186
    If your boring an ellipse the axis of the cutter isn’t perpendicular to the table or the vise
    Mark
  14. #12
    Mar 2005
    Kansas
    7,894
    486
    3757
    To bore an ellipse of 1.2485 x 1.25 by using a spindle centerline nonparallel to the feed axis would require the spindle centerline to be offset by 2.8 degrees.
  15. Likes boslab, dian liked this post
  16. #13
    Feb 2005
    9,262
    14979
    11103
    I have questions.
    1) Are you boring in and then boring out? If so, and already suggested,
    bore down, stop the spindle and then pull out and see what happens.
    2) How are you measuring the hole?
    3) Do you have a cranky X motor and its oscillating?
    I'm voting for slop in the Z axis ways.
  17. #14
    Dec 2005
    UTAH
    552
    71
    47
    My guess is that the machine is not level so the head is out of square with the table. Leveling the machine will effect the tram on each axis. I have a shop where the concrete slab moves from time to time and we have to relevel the machine about twice a year. But I have to admit I've never seen a boring head make an elliptical hole.
  18. #15
    Dec 2008
    New York
    10,338
    2681
    Default part warpage
    also some parts warp considerably when unchucked and have had time to think about it.
    I have seen bore go out of round that is days later and off the machine, sometimes if part is chucked too tight loosening a vise you can immediately measure a bore go out of round. other parts you might measure out of roundness, hours or days later.
    just thought I would mention chucking or clamping pressure effects and parts warping after some time has gone by.
  19. Likes Bobw liked this post
  20. #16
    Feb 2005
    9,262
    14979
    11103
    Quote Originally Posted by DMF_TomB View Post
    Had some castings a while back, delivered the first couple immediately after machining and the rest sat
    around while the customer got their shit together. Thin wall, really complicated, large (for me, not Tom).
    Every fricken hole went out of round and/or shrunk sitting around for a year. Bunch of linear
    dimensions from one side to the other moved. Really wasn't too bad, the bearing bores came back
    round when a bearing went in there, and the smaller holes for bushings and what not, I just re-reamed them.
    It all went together just fine.
    I couldn't believe how much those castings moved sitting for a year, it was an eye opening experience.
  21. #17
    Mar 2005
    Kansas
    7,894
    486
    3757
    Quote Originally Posted by Bobw View Post
    Just for curiosity's sake, what material were the castings?
  22. #18
    Feb 2005
    9,262
    14979
    11103
    Quote Originally Posted by gbent View Post
    Mil-A-21188 A356 class 11(eleven) temper T6.
  23. #19
    Jun 2015
    Minnesota
    529
    9
    185
    What about something simple like distortion from work holding? Is the work being held in a vise? Is the roundness error being measured while the work piece is still on the machine or when taken off? Or is it measuring the same regardless?
  24. #20
    Dec 2008
    New York
    10,338
    2681
    even a simple mill vise can squeeze or compress a part and when unchucked part bores often go out of round
    this is often seen with lathe parts too. a 3 jaw chuck when part unchucked bore is often rounded triangle a bit, just saying bore can distort more than simple oval, depends on how it was chucked
    also mill parts, if bore off center often many materials distort or metal might be harder near skin where rolling forces work hardened part material more. this is usually why cold rolled steel milled more on one side will bend / distort when unchucked
    castings often the center of thicker sections cooled slower when casting poured compared to casting skin which metal cools quicker, thus often there are different material properties in the same part (even if cast or rolled), this often why (a opinion) machined castings distort
    obviously if you open up a off center pilot bore alot than it will machine not round due to varying deflection from varying loads. for example 1.5" dia hole and 0.1" off position trying to open bore to 2.000" in one pass, longer length boring bars can deflect considerably under load.
    amount you are boring can effect bore roundness
