mill in a corner
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    Apr 2021
    12
    31
    Default mill in a corner
    I'm in the process of packing up my late fathers shop and moving it across country. I'm trying to come up with a good layout. I have a 1200 sq garage that double as my wood shop. I'm kicking the trucks out and going to make it all shop, planning on walling off one bay, 13' x 30', to set up the machine shop. I've see alot of folks place a mill at a 45 in a corner and was wondering what the advantage of that is. I will have a mill, lathe, surface grinder, horizontal mill (maybe), bench and storage cabinets in there.
    Apr 2017
    372
    83
    177
    Its space efficient. My mill is in the front corner of the workshop next to a single car garage door.
    I open the garage door and stand at the opening to run the x axis.
  3. Likes sparky30_06 liked this post
    Jan 2005
    Houston
    7,233
    1369
    4236
    I used to have mine in a corner but found it limited my ability to put long pieces in the mill. Like if you want to work on the end of an 8' stick. It also makes the mill hard to clean/sweep around the back side. And side sides. I moved the mill along a wall and keep my Jane Fonda ThighMaster in the corner. If that ThighMaster can keep Hanoi Jane from falling through herself, it's gotta be worthy of a place in my shop.
    Aug 2004
    Virginia
    2,930
    241
    1374
    Please don't mention her name. I was actually in Vietnam when that assclown went to Hanoi. If I could have, I would have shot the bitch right there and then. Still bothers me to hear her name.
    Jun 2012
    Michigan
    14,242
    4854
    5136
    mill or drill press should be placed along a wall, not in a corner because you will eventually have a long part job. IMHO
    Surface grinder sparks and throw-direction to a wall not to an aisle way.
    Try to set travel limits to still allow a small pushcart to pass ends.
  7. Likes sparky30_06 liked this post
  8. #6
    Sep 2008
    Canada
    1,720
    673
    686
    I like my Bridgeport on a pallet- one made to fit. Mine lives in the corner unless I’m doing something long then just pull out the machine. Simple, and anything else that can go on a pallet is bolted to one for easy use and storage.
    Those of us with small shops need flexibility.
    L7
  9. Likes Nmbmxer, sparky30_06, Bobw, DrHook liked this post
  10. #7
    Aug 2008
    Sussex, England
    3,566
    15
    837
    Do you have a second door into the garage? If so orientate the mill (and drill) so a long workpiece can poke out through that door.
    My Bridgeport is pretty much into a corner but orientated so along workpiece can poke out through the door and over the veggie plot. Standard position is at a small (10 - 15°) angle so the into shop dimension is restricted to maybe 4 ft. If I really need length its no great issue to pull the machine forwards a little and swing so the X axis is aligned with the door. Gives me about 12 ft inside the shop. Longest so far was just over 14 ft but that job had to wait until after harvest time so the runner bean and pea frames were out of the way!
    Pollard pillar drill sits next in from the Bridgeport so can play similar tricks, albeit with less into the shop space.
    Rapidor power saw is set so long stuff can poke out the main door with maybe 9 ft clear on the cut side. I have sufficient supports to handle 20 ft bars.
    My shop layout just grew over time. Effective enough but it could stand a full replan.
    Clive
  11. #8
    Oct 2020
    PORTUGAL
    167
    54
    65
    My shop is a 20' sea container so I'm struggling with space.
    My mill went inside just an hour ago, it takes up 1/3 of my shop!
    After much thought, I realized it simply has to have retractable castor wheels, so it can be rotated or pushed from side to side as required to accommodate work.
    It will take a while the make the castor wheel system so for now it's a space hog.
  12. Likes sparky30_06 liked this post
  13. #9
    Sep 2005
    Fayetteville, close to Pond Bank, Pa.
    255
    75
    73
    Quote Originally Posted by crossthread View Post
    I used to feel the same then forgave her.With that burden off my back it doesn't hurt as much.
  14. Likes cyanidekid, DrHook, Billtodd liked this post
  15. #10
    Jun 2008
    VA
    814
    212
    327
    At home my manual mill is in a corner and boxed in with toolboxes on either wall. It stays on timber’s and if I need to clean it or a part doesn’t fit the cord is long enough to easily pallet jack it a few feet forward and give it a spin if required.
  16. Likes sparky30_06 liked this post
  17. #11
    Jan 2005
    Houston
    7,233
    1369
    4236
    "Please don't mention her name. I was actually in Vietnam when that assclown went to Hanoi. If I could have, I would have shot the bitch right there and then. Still bothers me to hear her name."
    That's precisely why it's important to use her name. People have a bad habit of forgetting, and for the young people, it's important they learn it. Forgiving and forgetting is the biggest insult of all.
  18. #12
    Feb 2010
    Illinois, USA
    688
    29
    209
    Depending on the size of the machine, 1 or 2 pallet jacks solves machinery location issues in a matter of minutes. I moved my 10,000 lb. Monarch lathe just the other day about 4' in one direction using 2 pallet jacks, a long 6" X 6" timber in front, and my skidloader with forks to do the pushing. After cleaning under the machine, I reversed the process and pulled it right back where it was.
    Point being, your work, and the size of the stock you're milling, will dictate where you can put something. In a pinch, a pallet jack will allow you to move a machine out of the corner for a bigger (rare) sized part. When you're finished, put it right back where it was with the pallet jack. I paid a total of $125 for both my pallet jacks ($50 and &75). They're both rated at 5500 lbs. each.
  19. Likes sparky30_06 liked this post
  20. #13
    Jun 2018
    New Mexico
    190
    262
    86
    Quote Originally Posted by karl View Post
    There are persons that don't deserve Forgiveness. Some from WWII others from Viet Nam.
    ...lewie...
  21. Likes mike44 liked this post
  22. #14
    Apr 2021
    12
    31
    thanks for the input guys, I'll be putting the mill flat against the wall and the surface grinder throwing sparks into the corner
  23. #15
    May 2009
    Wyoming
    3,574
    9273
    6042
    In the pantheon of treacherous cunts, her place is right there with Tokyo Rose. She should have done time. In generations past she probably would've been shot.
  24. Likes reggie_obe, Dan from Oakland, mike44 liked this post
  25. #16
    Oct 2020
    PORTUGAL
    167
    54
    65
    That sounds like a plan; grinding grit is bad, contain it in the corner.
  26. #17
    Oct 2005
    22,566
    Quote Originally Posted by sparky30_06 View Post
    You could cut a hole in the wall.....
  27. #18
    Apr 2018
    9,233
    4481
    Hmm. You went halfway around the world to murder people who'd done nothing to you, because some drunk in Washington had a paranoid nightmare about commies under the bed, and you're upset about Jane Fonda.
    That makes sense.
  28. Likes cyanidekid, SIP6A liked this post
  29. #19
    Sep 2004
    Arkansas
    77
    5
    31
    Please don't insult the Soldiers, Sailors, Airmen and Marines they were serving their country. I will say no more.
    Bob Williams
  30. #20
    Apr 2018
    9,233
    4481
    Quote Originally Posted by rwilliams View Post
    The guards at Auschwitz were serving their country too. Sometimes conscience needs to come before country.
