Terry Keeley
Titanium
- Oct 18, 2005
- Toronto, Canada eh!
The OD of the nose of my spindle is out a couple thou., I'm trying to true it up. The MT2 taper is also out (only a couple of tenths) but it has a nice score mark where something spun in it so I might re-grind it.
I'm having a problem setting it up in my lathe. It has two bearing shoulders to indicate from. If I get one running true the other is out 0.015" or so and vice versa. I'm pretty sure I need them both running true to the lathe spindle to true up the nose and taper? Then I was going to move the steady rest into position being sure not to tweak the shaft away from the lathe's center line.
The lathe has been leveled and aligned with a test bar, it cuts absolutely straight over that distance and more.
What's causing this? Is my 4 jaw out?
