Mill spindle truing - set up problem.
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Oct 2005
    CANADA
    Ontario
    854
    140
    271
    Default Mill spindle truing - set up problem.
    The OD of the nose of my spindle is out a couple thou., I'm trying to true it up. The MT2 taper is also out (only a couple of tenths) but it has a nice score mark where something spun in it so I might re-grind it.
    I'm having a problem setting it up in my lathe. It has two bearing shoulders to indicate from. If I get one running true the other is out 0.015" or so and vice versa. I'm pretty sure I need them both running true to the lathe spindle to true up the nose and taper? Then I was going to move the steady rest into position being sure not to tweak the shaft away from the lathe's center line.
    The lathe has been leveled and aligned with a test bar, it cuts absolutely straight over that distance and more.
    What's causing this? Is my 4 jaw out?
    Mar 2005
    Northwest Indiana
    3,799
    540
    659
    In short, yes. The jaws are probably not perfectly square. Not unusual in the least. Put a stop in your chuck so that the jaws are only grabbing by 1/4" or so (or use some 1/8" copper shim on each jaw or wrap a copper wire around the part) and tighten the jaws only just a little bit more snug than it takes to keep the tailstock end from falling, then tap the tailstock end true. Snug the jaws a bit more while rezeroing the chuck end, then tap the tailstock end true again. Reiterate until both ends are zeroed and chuck is good and tight, then add steady rest.
  3. Likes 4GSR, vegard liked this post
    Apr 2006
    Manchester, England
    7,575
    1007
    4527
    I agree with eKretz, you're gripping too much of the spindle in your chuck. As he says, holding it by 1/4" with some softer material is the way to go.
    Regards Tyrone.
    Jul 2006
    Hillsboro, New Hampshire
    5,766
    1369
    3996
    You might want to do an initial test of the spindle to ensure it's not bent. If you have a surface plate and two good V-blocks you can set the bearing surfaces on, you can then carefully spin it and observe (or use a DTI) if there's any wobbling or other signs of lack of straightness.
    Dec 2004
    uk
    13,702
    4202
    6401
    Is the spindle your trying to re-machine bent? Have you sat the 2 bearing race surfaces on V blocks and then used a DTI to confirm straight?
    You need to straighten or confirm straight before you move to the step you appear to be on
    If it is straight, yep you need less in the chuck jaws so it can be pulled into true hat far out. its common to get the chuck end running true then tap the other end lightly with a mallet to get it running true.
    Jul 2006
    5,766
    1369
    3996
    Quote Originally Posted by adama View Post
    Rumors prove true, Adama and I are the same person...
  8. Likes Terry Keeley, litlerob1 liked this post
  9. #7
    Sep 2007
    Maryland near DC
    335
    76
    65
    I believe this is referred to as “spooky action at a distance.”
  10. Likes Terry Keeley, jspivey liked this post
  11. #8
    Jun 2012
    Michigan
    9,525
    2900
    3170
    If the part has a center on the chucked end between center and steady might work.
    A soft slug center put in the chuck and tool bit turned to 60*.
    Some times a single strand of soft wire perhaps 1/32 - 1/16 diameter can be wrapped around the chucked end and the then part indicated in to take the chuck jaw wobble out of the truing.
    *I see some have said hold only the very end of the part.. a good method also.
  12. #9
    Oct 2005
    CANADA
    Ontario
    854
    140
    271
    The spindle is straight, I checked it in V blocks on my surface plate and all good.
    Thanks eKretz and Tyrone! Now I remember reading about this but forgot it somehow.
    I've decided to try and lap the nose instead of grinding since it's so close already and am making a brass mandrel/lap to fit the spindle taper. Without taking it off the machine I'll try fitting the spindle to it with a dead center in the tail stock. Had to add a 0.001" shim to my tail stock so now it's dead nuts, hopefully it'll work. If the tail stock pulls the shaft out of alignment I'll just add the steady.
    If not I'll cut some copper strips and tweak away!
  13. #10
    Jun 2012
    Michigan
    9,525
    2900
    3170
    The lathe spindle can be straight perfect to a test bar...but still a 4 jaw (any chuck) even with the part indicated to dead zero at one place may have wobble inside the chuck.. so a small diameter part will take on some of that wobble... with it showing up some place down the length of the part.
    QT: [Is my 4 jaw out?] Yes nothing is perfect..Even the best chuck brand new is not perfect..
    and still one has to make near perfect parts..
  14. #11
    Jun 2012
    Michigan
    9,525
    2900
    3170
    That part might be best finished held in its own bearing as assembled..
  15. #12
    Oct 2005
    CANADA
    Ontario
    854
    140
    271
    Quote Originally Posted by michiganbuck View Post
    Thought of that but was leery making swarf right next to a $500 pair of matched spindle bearings!
  16. #13
    Jun 2012
    Michigan
    9,525
    2900
    3170
    I was talking about in the mill (or what) yes with having extra protection like oiled spindle nose and a tight tape wrap to ride on that nose so as good/tight as mist grinding spindles
    *But yes, grinding and metal machining machines should be kept far apart.
    I agree with checking the part on a plate...perhaps in two v blocks or two good parallels...just rolling on the plate.
    Perhaps the part needs straightening not machining.
    Some times a part checks odd when taken from its assembled position..or seems to check odd.
    other: [score mark where something spun in it so I might re-grind it.] some time a blue-up and hone can restore a injury..
  17. #14
    Oct 2011
    West-Central Illinois, USA
    1,128
    1790
    502
    Quote Originally Posted by Terry Keeley View Post
    The only thing I ever stick on the outside of a little mill spindle is a rig to sweep bores??? Unless it’s spinning at some insane speed or you really want to fasten a tool to it, it doesn’t matter.
    I agree with bearing dia's in V blocks & testing the bore since you have it out. If they all agree then bending it is not needed as the bearings to nose taper is straight.
    I’m gonna have to check my B’port knock off now...
    Matt
  18. Likes michiganbuck, Red James liked this post
  19. #15
    Oct 2005
    CANADA
    Ontario
    854
    140
    271
    Just a quick update. I used some brass shim stock wrapped around the spindle (1/4" wide) and was able to get both bearing seats running very close, thanks guys!
    Trued up the shoulder where the spindle bearings rest as well as the nose.
    Now to re-grind the MT2 taper with my Falcon G-1...
  20. Likes michiganbuck liked this post
  21. #16
    Jun 2012
    Michigan
    9,525
    2900
    3170
    Qt:[The MT2 taper is also out (only a couple of tenths) but it has a nice score mark where something spun in it so I might re-grind it.]
    I take a round hone to hone a bug/score..then with an old taper tool or center with a bit of fine rouge or compound see if I can
    lap restore a little off-center ID taper...doesn't always work but if it does it saves a lot of work.
    Used to use much the same method to move a part center .00005/.0002 (or more) with putting the off end on a abrasive center lap to put a heavy hand on the part and rotate it perhaps 5 to 20 degrees back and forth to lap the part center the way/direction it needed to go. yes the good or other end on a machine center.
    That falcon G-1 is a very nice device...
  22. #17
    Oct 2005
    CANADA
    Ontario
    854
    140
    271
    lap restore a little off-center ID taper...doesn't always work fut if it does it saves a lot of work.
    Ya, thanks for the suggestion, my toolmaker buddy had the same advice.
    I made a brass lap and gently tried to true it up but the lap just followed the existing run out which is actually about 6 tenths near the big end.
    I got the Falcon about 20 years ago to ID grind some hard chromed cylinders for my R/C boats and have used it very little since, seems they're discontinued now. Same company that makes the Planet line of air grinders to do "jig" grinding on a mill.
    We made a cast iron holder with a precision lead screw and are able to in feed in tenths, it'll straighten it out!
  23. Likes michiganbuck liked this post
  24. #18
    Sep 2009
    barcelona, spain
    2,379
    481
    1299
    Not to be negative ..
    but usually grinding will get to 2 microns in overall straightness, taper, tir, from true, or better on industrial setups.
    Endless examples of skilled people doing VMC taper fixes, etc.
    Running a VMC spindle into a mounted point will knock off the high spots.
    And many people doing BP-type fixes with some lashups, often to very good results.
    Rigid, proper, lapping should deliver good results to much better than 1 Micron tir / 1mu // 100 mm out.
  25. #19
    Oct 2005
    CANADA
    Ontario
    854
    140
    271
    Quote Originally Posted by hanermo View Post
    I think if I had a good solid mount for the lap it mighta worked out better but I dunno, I also see how a lap would follow the existing run out as it did in my case.
    If I get 2 microns (0.00008") TIR by grinding it I'll be a happy camper!
  26. Likes eKretz liked this post
  27. #20
    Mar 2001
    Switzerland
    2,469
    2108
    1028
    If it's not bent I would have not touched the bearing seat. And would have tried a reamer on the Morse taper before grinding. And if grinding was required would do it in the machine like buck said.
    Sent from my SM-G960F using Tapatalk
  28. Likes Red James liked this post
