Milling chatter in slow motion and audio spectrum analysis video
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Endmill chatter at 20,000 Frames-per-Second - YouTube
Very interesting video, although for full disclosure the guy is using a CNC router rather than a proper VMC. But the principles are there, and if anyone here has the capacity to do similar on a real mill it would be great to see the results.
See? Home Shop Harrys do have their place (especially when they know a bit of science and have access to HS-video cameras...).
From my limited knowledge would it be fair to say chatter is in fact resonance?
You hit the natural resonant frequency of the system, to overcome somthing needs to change, speed feed clamping etc?, when I get chatter I tend to change speed (the worst chattery thing I ever turned was about a 12’ ring on a craven lathe, awful, it rung like a bell, we did it on a vertical no problem
Just thinking
Mark
Just thinking
Mark
Hi Mark,
NRF certainly plays a role, but I think it's more complicated than that, due to the variations in force of the cutter digging in or bouncing away.
In our machines it's not as dramatic (at least, I don't think so) because of their inherently greater stiffness, but that's why I'd love to try to film my own HS video of cutters at different parameters on a real VMC (well, just a Haas VF-series), to see how much motion can be seen under abusive cutting.
A couple of things, I think I work with people that move that slow and it is real interesting seeing the endmills start to break up and shatter.
Just thinking
Mark
Yes, chatter is a kind of self-sustaining resonance. The resonance is made to oscillate due to power amplification, where intermittent contact between tool bit and work causes the tool and/or work to ring in unison.
What I was thinking , would it be possible to use audio to actually find out what frequency to avoid, like ringing a grinding wheel, bash it record the audio to give you a predictable chatter zone?, also is this resonance implicated in say fatigue in aircrafts or example, or cracks in pipes
So many thoughts pop in excuse me, do electrical systems have resonance
Mark
Mark
This is actually the whole point of MSC's MillMax program. We've done a test with it and are looking at another. Took a 3/4" endmill doing a full width cut about 5/8" deep and you couldn't even hear it running using the settings they recommended.
MW Services MillMax Pilot Program - Landing Page Video - YouTube
*added video link
Mark
Yes. There was a company advertising a service to do just that several years ago. Very expensive, had to be done for every tool / workpiece combination, and since the workpiece changes as you cut it you'd have to do it for every cut to get the optimal parameters. Makes sense if you're trying to squeeze the last drops out of long run production.
I think I might have even seen something about a machine that could do it on the fly.
I don't get the viewpoint that you have to take a certain sized cut to avoid chatter and rubbing though. I regularly shave tenths to size in prototype parts on my five year old Haas, sometimes with 8" gauge length cutters, in 17-4 H900 and Ti grade 5. Works a treat every time. Maybe the cutters I'm using are better than those people had when developing that opinion in past decades?
Pretty sure MSC offers a service like that. I seem to remember getting an email from them not that long ago about it.
Yes, it was already mentioned. It involves putting a vibrometer or something similar on the spindle and tapping the spindle with a glorified hammer (to simplify it) and checking each individual piece of tooling to get the most stable settings that avoid resonant frequencies. Sometimes there is only one "sweet spot" in terms of speed/feed and sometimes there are many. It apparently works pretty darn good, especially for troublesome long reach tooling or thin-walled parts - areas where the extra help can really be used.
Too bad he doesn't have a real machine. The work piece moves .009" and the tool .02"?
I thought the same thing when I saw this video the other day.
His machine is such a piece of shit for this type of test that it actually tells us nothing.
I wouldn't call it "nothing", but as I already said it would be nice to do the same sort of tests on a real machine. A lab I've worked with has some fancy strobe capability, but that's a "lossy" method, I'd rather use a real HS camera for capturing all the data. I need to contact them and see if they have anything I can borrow.
With Covid protocols, it may be a while...
