I am a novice machinist using a Jet JMD-15 Milling/Drilling machine (I realize this is a fairly light duty machine). I need to mill a chromed 1 1/16" (3/8" socket) crowsfoot down to a thickness of 7mm.
My question is whether I can mill the crowsfoot as is or do I need to do something else prior to milling (anneal, remove chrome, something else)? Or, would it be best to simply use a grinder to grind it down to the desired thickness?
Thanks for your help!
