Milling End of DOM Tubing
Results 1 to 15 of 15
    Feb 2021
    Montana
    Default Milling End of DOM Tubing
    Hey guys/gals! I am very new to milling/machining. I would like to know the best way to mill the ends of some DOM tubing. I am making bushing housings for some leaf spring shackles and they need to be exactly 2.5" wide. The DOM tubing is 1.5" x .25" wall.
    I have a JET mill/drill. Should I use the tip or side of the end mill to remove excess material off the end of the 2.5" piece of tubing? Also, should I place the tubing vertical or horizontal in the vise? Just looking for the best technique.
    Oct 2005
    21,073
    Quote Originally Posted by Johnnygrant View Post
    Why not chuck it in the lathe ?
    "exactly 2.5" wide" so your tolerance is +/- .125 ?
    Belt sander time.....
  3. Likes cyanidekid, woodchuckNJ liked this post
    Feb 2007
    St. George, Utah
    1,262
    817
    851
    Hello, Johnny. If you're just trying to adjust the length, a lathe would be 1st choice if you have one. Holding a round piece vertically in a vise requires at least one V-block, otherwise it's sure to shift during the cut and that usually trashes your endmill. Gripping the part horizontally and side-milling the ends is much safer assuming your vise has deep enough jaws to reach at least to the halfway point on the tube. Again, if you have a lathe it will be a lot faster.
  5. Likes cyanidekid, Johnnygrant liked this post
  6. #4
    Jan 2007
    Flushing/Flint, Michigan
    10,147
    569
    8306
    Before this gets locked.
    Vertical and not a endmill but a facemill..
    One pass and done.
  7. #5
    Feb 2007
    St. George, Utah
    1,262
    817
    851
    . . .not a endmill but a facemill...
    Maybe, but it is a mill-drill.
  8. #6
    Jun 2016
    New York
    2,073
    1586
    1007
    Correct, milling is the wrong way to hit this. assuming you don’t have a decent lathe that can part off 1.5 X .250 easily, saw it to near size in a horizontal bandsaw, (or cold saw, but don’t think you have one), then set up a stop in the lathe (spider or workstop) and turn to length. First a bit oversize, square one end on all, then set to final size and face off the other end.
  9. Likes Johnnygrant liked this post
  10. #7
    Feb 2021
    Montana
    Thanks for the info guys! I don't have a lathe, just a mill/drill. I have a horizontal band saw, just trying to get the right tolerances with a finishing touch.
  11. #8
    Jan 2009
    Maine, USA
    232
    139
    108
    With your tools hold the material horizontally in the vice and side mill to length. Clean one side, flip and clean the other, measure while in vice, cut to final dimension.
  12. #9
    Oct 2005
    21,073
    ...and what would those tolerances be ?
  13. #10
    Oct 2005
    Wilmington DE USA
    2,281
    370
    484
    laying the tube down in the vice will require an end mill with at least 1.5 length of cut....in a mill/drill?
    I'd suggest investing in a v_block with tube standing on end
    finish 1 side of all of the group
    flip and start with finishing 1
    once the height is established finish the rest without adjusting spindle height( checking as you go)
  14. #11
    Oct 2013
    The Gorge, Oregon
    218
    41
    168
    Put a 1” expanding arbor in the mill chuck and slip the DOM over the arbor. Put a cutting tool in your vice and move the rotating DOM horizontally over the cutting tool. Sorta like an inverted vertical lathe. Since you don’t have a lathe and you may be trying to do this on the cheap you can get the expanding arbor and tool bit from CDCO.com.
    Also, since this setup is not a lathe, be cautious about trying to take to big of a bite or you’ll knock your mill out of tram.
  15. #12
    Nov 2003
    5,829
    205
    1998
    I could be wrong, but I suspect the OP has SQUARE tubing so a vee block may be unnecessary.
  16. #13
    Feb 2007
    St. George, Utah
    1,262
    817
    851
    Quote Originally Posted by EPAIII View Post
    Could be, but 'DOM' and 'bushing housings for leaf spring shackles' make me think round.
  17. Likes sfriedberg liked this post
  18. #14
    Langley, B.C.
    1,848
    407
    1081
    Quote Originally Posted by Gordon Heaton View Post
    I'm sure that's the case. The only DOM square tube I've ever seen is the 2-1/2" stuff they use for trailer hitch
    receiver tubes. They put something through it to remove the slag from the inside seam...
  19. #15
    Feb 2020
    Maryland
    114
    39
    Just because you now have a mill does not mean you need to use it for everything. It's just a freaking leaf spring shackle bushing so any precision is wasted. Just cut the tubing off on the bandsaw and get on with life. Plus or minus 1/16" is good enough. Use the mill when a thousandths means something.
  20. Likes digger doug, Gordon Heaton liked this post
