milling head drop in the z axis
Likes Likes:  0
Results 1 to 8 of 8
    Apr 2021
    AUSTRALIA
    Default milling head drop in the z axis
    hi guys i am new to the forum but i was wondering .if you designed a milling machine head z axis which was driven up and down with a lead or ballscrew with a handle. With the cutting forces and weight of the head would the leadscrew be driven down dropping
    May 2011
    New Jersey
    2,909
    287
    1604
    There's a reason this hasn't been done...I mean really, just think about it for a few minutes then revisit this thread.
    Apr 2021
    AUSTRALIA
    i have seen it done for cnc conversions on mill like sieg x2 but i wonderered does it need to be cnc driven and why not a handle if this is not the best way to do it for a manual mill what is if it is obvious to you sorry but i am not fully conversed with machine design but i have to learn from others so if you could clear it up
    May 2011
    New Jersey
    2,909
    287
    1604
    Quote Originally Posted by anthonycosier37 View Post
    You would need thousands of dollars in ballscrew/nuts thrust bearings a sturdy ass casting and one hell of a brake. Otherwise there would be so much movement in pretty much everything a cut would not be successful...well maybe in jello.
    A seig x2...come on really. It's a piece of shit to begin with.
    Apr 2021
    AUSTRALIA
    how is it done normally then
    Jun 2008
    VA
    787
    204
    311
    Most every vertical machining center has the head driven up and down by a ball screw, the high efficiency will cause the screw to back drive which is why they usually have a counterweight to offset the weight. If you had a manual mill with a ballscrew on z you'd need a brake to counteract the cutting forces which can't be counterbalanced. Same way you have to lock table if you have ballscrews on the x and y unless you want to hold them the whole time.
    Apr 2021
    AUSTRALIA
    ok thank you that makes sense but why wouldn't a counter balance work on a manual mill
    May 2011
    New Jersey
    2,909
    287
    1604
    A counterbalance alone will not negate the forces generated by cutting.
