Milling machine for shop with 80-1/2" ceiling
Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    Aug 2017
    Ohio
    124
    35
    Default Milling machine for shop with 80-1/2" ceiling
    The shop space I have has a ceiling of 80-1/2 inches. Looking around, it looks like you need at least 84". I could theoretically cut a hole into the ceiling between the rafters, but i'd like to avoid that. I had originally been looking for a hobby size mill (Rockwell 21-100, Clausing 8520, etc), but the larger machines are much more available in my area, for between 1k-5k and I can reluctantly live with parking my car outside year-round.
    I saw on a different post that a cincinatti toolmaster only needs 72". Does anyone have any suggestions for other shorter stature machines I should be searching for or keeping an eye out for? Thanks!
    Nov 2006
    Southern California
    1,014
    7
    119
    Quote Originally Posted by Domodude17 View Post
    I would usually recommend a Millrite mill, but looking at the manual it is 82" tall.
    Burke Machine Tool Co. - Publication Reprints - Millrite maintenance instructions and parts list | VintageMachinery.org
    Sep 2017
    New Jersey
    213
    52
    Quote Originally Posted by crrmeyer View Post
    Bridgeport 1hp j-head with pancake motor.
    79” ceiling, with an inch to spare!
    Oct 2005
    17,262
    Saw cut the concrete pad.
    --------------OR------------
    Unbolt garage walls and raise building
  5. Likes crrmeyer, MichaelP liked this post
    Nov 2006
    Southern California
    1,014
    7
    119
    Early Index (aka Wells Index) mills such as the model 40 or 55 were in the 74" to 76" tall range. Later larger ones like the 747 were 82" even with the 1HP pancake motor on the step pulley version.
    Jul 2003
    savannah, jaw-ja
    1,797
    1394
    442
    Don't forget the drawbar in all your measuring... DAMHIKT
    Feb 2004
    peekskill, NY
    25,079
    4996
    Low headroom special:
  9. Likes AD Design, Metalo, Hopefuldave liked this post
  10. #8
    May 2005
    Interior British Columbia
    2,444
    255
    780
    Deckel FP2.
    Schaublin 13.
    Lots of low headroom mills.
    But if you own the house, Get right on a wee reno in the garage and buy whatever's cheapest. Punching out enough space to put a taller mill in there is a decent weekend project.
  11. #9
    Jan 2005
    Houston
    6,120
    706
    2854
    Jim, what model Hardinge is that mill?
  12. #10
    Apr 2018
    3,973
    1794
    An Abene would be pretty nice, if you could find one.
  13. Likes Hopefuldave liked this post
  14. #11
    Apr 2005
    Beaverdam, Virginia
    8,113
    913
    3899
    Quote Originally Posted by Rudd View Post
    I guess you can always tilt the head if you have to remove the drawbar.
  15. Likes MichaelP liked this post
  16. #12
    Nov 2003
    5,345
    187
    1732
    When I purchased my mill, I went through almost the exact same thing. My shop, at the time, was in a trailer and the ceiling was at a number very close to yours. A general caution that I learned in the process is that specs. can mean different things. So you need to be real careful about any specs. or even actual measurements that you are given. For a vertical mill, it is the MAXIMUM height that counts and that may not be the height that the seller lists. Many people think the most important height is the minimum that can be had by lowering the head so that it can fit through a doorway. That may be important and in some situations it may be the controlling/deciding factor. One place where I worked had a large, open area with a vertical clearance over 16 feet. BUT the tallest door leading to it was less than 7 feet high and that was a problem. Anything taller had to be brought in sideways or in pieces. A real PITA.
    Anyway, back to my trailer shop. I knew that I would be there for several years before I could move into a larger shop, which I have now, so the mill had to fit, not only through the door in it's minimal configuration, but also under the ceiling at it's max or at least close to that. I also wanted to avoid certain things, like round column mills. I did have to do a lot of checking and looking, but in the end, I was able to find several models to choose from. The one that I purchased has a minimum height of 72.5" (not what the specs. say) and a maximum of 78" with the head at it's highest point on the dovetail column. We are not supposed to talk about such things here so I will PM you with further details. That model is no longer available, but there are many similar ones that are.
    If you do not like the route that I took, then you just need to keep looking. There are suitable mills out there. Persistence pays off.
    PS: I have rarely had to remove my drawbar, but my head does tilt 90 degrees so that was never a real problem. I did remove the drawbar on another mill to repair it and add a better thrust washer so I guess that could be a consideration.
  17. #13
    Apr 2004
    Modesto, CA USA
    7,352
    1277
    I read, probably here, one guy had his mill in the basement. He drilled. a hole in the floor of a upstairs closet for the drawbar when he had to make a new one. Normally the hole had a big cover or cork in it to keep out shop smells. I guess if a collet got stuck he had to go upstairs to pound on the drawbar from the closet.
    Bill D
  18. #14
    Virginia
    30,393
    7561
    9504
    My USMT Quartet combo mill drawbar is around 79", my ceilings 96", so I can get at it with a deadblow - as #9 B&S do need now and then.
    I still have to rotate the head if/as/when the drawbar must be PULLED.
    Easy solution is any of many horizontal mills - not all of them small. Then a vertical head attached, regardless of which one you use mostly. The 40-taper K&T angle head when on the Quartet's 5 HP spindle doesn't add ANY vertical height. OTOH, it eats a good deal of daylight.
    Abene has been mentioned. Some of the Van Normans may fit as well?
    The larger sliding head Nichols is about as small as I'd want, but that really depends on what you plan to DO with your mill.
  19. #15
    Apr 2005
    Beaverdam, Virginia
    8,113
    913
    3899
    Quote Originally Posted by Bill D View Post
    Bill D
    There was a guy that drilled a hole up through the wood floor and put a brass plate over it. Lucky for him it came up under the couch. That was a member here, I forget who it was. I wonder if his wife ever cleaned under the couch or wanted the furniture rearranged and he got busted.
  20. #16
    Virginia
    30,393
    7561
    9504
    Quote Originally Posted by Dualkit View Post
    Meah... machinists aren't exactly FORBIDDEN to do a touch of high-precision reinforced woodworking, alloy framing, through-body porcelain tiling or laminate veneering.
    Gar-ron-tee if any among us wanted an "invisible" flush hatch set in the middle of an entrance hallway, living room, kitchen, bath, commercial basketball court, heavy-metal nightclub dance-hall floor, or heavy jet aircraft RUNWAY, it could get done well-enough and bank-vault strong enough, too!
    Whom else would one ASK? A hollywood set scenery painter to FAKE it?
    Not as if yah had to do a hundred of them... but "that, too", if need be, and then..,, sumbudy has a "bizness", so "BFD".
  21. #17
    Jan 2005
    Victoria, Texas, USA
    4,219
    2491
    1091
    This is a little off topic...
    Height restriction never stopped my dad for bringing home a Avey No. 3 upright drill press that stood up 9 foot tall with the belt guard installed. It stuck up between the ceiling joists of the shop and don't ask how we did it. Never again!!!
    I have a Index 645 mill that is very close to 80" tall. As all said, let the motor hang up in the ceiling joists!
    Ken
  22. #18
    Oct 2005
    17,262
    Yup, this idea of buying a mill to fit the building, not the job needed, is very "harry homeshop" and the conversation needs to go to homeshopmachinist.com
  23. #19
    Virginia
    30,393
    7561
    9504
    Quote Originally Posted by 4GSR View Post
    Ken
    /Frustration mode ON/
    It doesn't HAVE to do. We be making a problem out of BYPASSING the most obvious of solutions. WHERE or on WHAT, a(ny) vertical head is MOUNTED.
    Yah LIKE a BirdPort head? Well.. they began LIFE as add-ons to horizontals. They are as good at that as they ever were.
    Yah do NOT like working with a horizontal's primary spindle?
    Just don't tool it up nor spin it up!
    Whatcha CAN use is more commonly than not a stouter knee and table than a BirdPort, and built from the factory with all-axes powered, and equipped with rapids as well.
    Add yer favorite head, BirdPort or other, mounted lower down? Yah STILL have plenty of "daylight" atop an all-around stouter chassis.
    Cheaply, too.
    Even "Grand Old" horizontals don't bring a lot of coin in a CNC'ed world.
    Middleweights often less-yet.
    Who knows? Yah MIGHT even find a USE for that "second choice" horizontal spindle ever' once in a while.
    /Frustration mode OFF/
    Put a gun to my head, I may even use the silly-annoying VERTICAL wimp-head now and then.
  24. Likes Rudd liked this post
  25. #20
    Feb 2004
    peekskill, NY
    25,079
    4996
    Quote Originally Posted by GregSY View Post
    That's a hardinge UM miller. An $800 wreck that I bought from dave sobel about 25 years ago.
    I even have a b'port M head that fits on it, but I never mount that up anymore. No need.
