Milling V Groove in AL
Likes Likes:  0
Results 1 to 13 of 13
    Jun 2002
    Boca Raton, FL USA
    180
    5
    Post
    I want to mill a 90 degree V-shaped groove about 0.250" deep in some 6061 AL. Are those 90 degree countersinks ok for this or is there a better type of cutter for this application?
    May 2006
    South of Boston, MA. USA
    775
    9
    Post
    At that depth I wouldn't use a c'sink. They make 90 deg. ang. cutters one type mounts onto an arbor used for a slitting saw, the other type is all one pc. much like a key cutter.
    Jackmo
    Jun 2005
    Pittsburgh, PA
    246
    10
    5
    Post
    There are 90 degree carbide mills, either 2 or 4 flute, that would probably be best for this project. I'd do it in a couple of passes, with high speed and feed, and WD-40 or kerosene.
    Look for "drill mills" at Enco.
    Mar 2004
    Granada Hills, CA
    498
    Post
    Couldnt you use a standard (square) endmill...and nod (or tilt) the mill head 45 degrees?
    nK
    Jan 2007
    Norfolk, UK
    21,416
    16783
    17633
    Post
    Quote:- Couldnt you use a standard (square) endmill...and nod (or tilt) the mill head 45 degrees?
    By far the best way of doing it, the cutting speed at the centre of a countersink/ small angle cutter is very low, and IME doesn't give a good finish.
    Take care. Sami.
    Dec 2000
    Bremerton WA USA
    10,720
    41
    4458
    Post
    Use a plain vanilla endmill and tilt the head.
    Feb 2007
    Mi. USA
    299
    29
    Post
    I just did a job last weekend, 4 pcs , each with 71 90* grooves. They were .040" deep on .100" centers.... I tilted the head and trammed it to
    a 5" sine bar. The job came off without a hitch.
    Also had to do 4 matching top straps with slots and clearence holes, also came off without a hitch. Tilt your head and use a sharp endmill
    and you will get good results.
    Jul 2004
    Vicksburg, MS
    4,929
    30
    263
    Post
    Or a horizontal mill with a double angle cutter will whip the job right out. No titling or tramming required.
    Dec 2003
    Albuquerque, NM USA
    565
    6
    Post
    Unless it's a LOOOONG peice, why not tilt the work?
    (don't have to re-tram the head)
    ...lew...
    Jun 2002
    Boca Raton, FL USA
    180
    5
    Post
    What do you guys think about the type of cutter shown here:
    http://www.discount-tools.com/mosda90-tin.cfm
    With this (if its worth a darn) I can turn the piece on its side and not tilt the head. Are these any good?
  11. #11
    Aug 2006
    Cape Cod, Ma
    521
    308
    129
    Post
    It will work, but I don't think it will give you as nice of a finish as a regular (sharp) endmill with either the work or the head tilted.
  12. #12
    Jun 2007
    New Zealand
    2,673
    31
    Post
    Cheap carbide Router cutters (intended for wood) make a pretty good job in alu alloy, as long as you don't have lots to do, they can be an economical alternative. They come in a 90 degree v-groove cutter configuration, and cut right to the center (although there will be a little smearing)
    Generally speaking aluminium alloys respond quite well to woodworking tools and techniques, even down to a hand plane for chamfering long straight edges, or a skil saw for cutting plate, up to say 6mm
  13. #13
    Jul 2007
    Tulsa, OK
    43
    Post
    Depends on if you need a true 45 deg. in the bottom of the groove. A carbide mill-drill doesn't leave a true V shape, but has a flat on the bottom. I cut about 80 or so grooves in cast iron w/ a single flute carbide etching tool. 1/4 inch one is about $20 I think. Worked great used 2 tools on 40+ parts.
