Racer Al
Stainless
- Feb 20, 2006
- Oakland, California, USA
I'm rebuilding the bottom end of my motorcycle (both the transmission and crankcase) due to a bearing failure and collateral damage. All of the bearing were replaced with new bearings from a local bearing supply house. My first question is more about business interaction than a technical question.
I approached the bearing supplier with a list of bearing part numbers which I copied from the OEM bearing part number stamped in the races or molded into the shielding. None of these bearings are particularly special - no funky flanges, high ball counts, thin races, etc...
The salesman claims it took three tries to get the correct bearings from their warehouse, and even then some bearings were shielded when I requested unshielded (at added cost to me, no doubt). When I went to pick them up, one pair was clearly wrong (not the same part number I'd requested), and the quantities were wrong on two other bearings.
Adding insult to injury, the salesman quoted me one price over the phone, and when I went to pick it up, the inside sales guy charged me a significantly higher price because he claimed that one bearing (a big, expensive one) had not been included on the ticket -- this final total was actually higher than OEM parts, not to mention that it took longer to receive usable parts.
Is this how all bearing vendors do business? If so, how the hell do they stay in business??!! Or, did I get sh!t service and screwed on the price, as well? Did I communicate poorly? Did I have the big neon "SUCKER" sign on my forehead? How could I have made this transaction work better?
Now, the technical question: One of the bearings is apparently a higher-class fit than the OEM part. On the output shaft, the OEM bearing will slide all the way down the length of the shaft, but the new replacement bearing will only slide on as far as the root of the splines for the sprocket then jams.
Presumably, the new bearing could be heated/the shaft cooled, or pressed on in a hydraulic press, but none of those solutions is viable for a motorcycle transmission. The ID of the bearing needs to be a looser fit so it can be assembled by hand.
Is it possible to enlarge the ID of a ball bearing? I don't believe I can chuck a bearing accurately enough to cut or grind with a fixtured tool (i.e. a cutting tool or a grinding tool in the tool post), but is it possible to hone the ID with a lap and not ruin the concentricity? It doesn't need much, only about 2~3 tenths. Then there's the problem of keeping the inner race from turning... If there are techniques for this situation, I'd like to hear about them.
Given my experience dealing with the bearing supply place, I'm not anticipating a positive experience requesting to exchange the bearing. How would you approach the bearing vendor to secure an exchange? Should I just suck it up and go buy a replacement, maybe from a different vendor?
I can measure to tenths, but I don't know how to specify a class of fit for the replacement. Any help there, perhaps a link on the subject, would be most appreciated.
Thanks for any advice.
