clarnibass
- Dec 23, 2015
Hi
I'm looking for a drill chuck with a minimum grip of 0mm. OK... 0.1mm is fine... but it's either 0mm or 0.5mm...
The good ones that I've found locally are Rohm. I have a chuck from them and the local distributor is good. Anything else is pretty unknown quality. I've only ever used keyed chucks (except on electric drills, etc.) and the only min 0mm chucks I see are keyless (keyed ones start at 0.5mm).
Rohm has the Spiro (about $170) and the Supra (about $80). Anyone with experience with those? Is the extra for the Spiro worth it?
They are available in various max diameter grips, is there any difference other than the max diameter?
I'll be using drills about 0.3mm to 0.9mm with this chuck, with the very occasional (i.e. almost never) smaller drills.
