I am at the point with my shop and racing where I have on demand needs for small, one off parts to be made. A spacer here, a washer there etc.
Mostly I would be handling nylon or delrin and aluminum, with occasional steel. And sometimes i will need to cut threads. Mostly metric.
The length of material would probably not be more than 6 inches long.. However, maybe longer at times. Diameter of material probably not more than two inches. But sometimes turning the OD down to certain sizes.
SO I need something that is relatively easy to use and setup. Something that is mostly accurate and repeatable. And also something that is not a pile of crap.
And no, I have zero tooling.
Any help or insight would be appreciated
