Mitutoyo dial caliper copper gib strip not staying in position
Results 1 to 11 of 11
    Jun 2002
    Gilroy, CA, USA
    306
    208
    17
    Default Mitutoyo dial caliper copper gib strip not staying in position
    I've had this set of calipers for a few years and I've never had any issues with them. The other day I went to use them and noticed that the copper gib strip had moved out from the end of the head. I've tried readjusting the screws but it keeps moving. There is a hole in one end of it. What should that hole be aligned with?
    Chris
    Mar 2005
    Indiana
    4,666
    1208
    1098
    Possibly one of the screws. I have a Mitutoyo dial caliper, I'll have a peek at it and let you know how it looks.
    Mar 2005
    Indiana
    4,666
    1208
    1098
    Yep. One of the screws is a dog-point, it locks into the hole or notch to prevent the gib sliding out. You probably don't have it aligned correctly if it's sliding out. When installed correctly you shouldn't be able to see the gib sticking out past the housing, it should be tucked inside at both ends. It's a little tricky since the gib is bowed like a leaf spring - the leading end tends to hang up on the way in. Once it sticks, use a toothpick or paper clip to push down inside the hole (gib screws both removed) by the leading end, that should allow you to push it the rest of the way in. Look down the hole to see when the notch is lined up, then put the dog-point screw in.
  4. Likes sfriedberg liked this post
    Jun 2002
    Gilroy, CA, USA
    306
    208
    17
    Thank you sir. I'll check it out and report back.
    Mar 2005
    Indiana
    4,666
    1208
    1098
    You're welcome. Don't forget to clean and oil the caliper and the gib while you have it apart. Gave me a good opportunity to do mine. I added a micro-dot of blue loctite to the side of the screws after they were started in the holes too. That way the adjustment doesn't loosen up over time.
    Jun 2002
    Gilroy, CA, USA
    306
    208
    17
    That was it. The point on the screw was so small that I missed it. Thanks again!
  8. Likes eKretz liked this post
  9. #7
    Jul 2006
    Hillsboro, New Hampshire
    8,964
    2149
    6217
    Minor correction for the record - the gib will be a bronze, not copper. Both for bearing, "springiness" and wear properties.
    [/pedant]
  10. Likes barbter liked this post
  11. #8
    Mar 2005
    Indiana
    4,666
    1208
    1098
    Haha, I purposely did not mention that so as not to look um, pedantic?
  12. Likes TeachMePlease liked this post
  13. #9
    Jul 2006
    8,964
    2149
    6217
    Quote Originally Posted by eKretz View Post
    Left to my own devises, I inevitably sink to "asshole teacher" level.
  14. Likes eKretz, barbter, TeachMePlease liked this post
  15. #10
    Oct 2007
    SPAIN
    3,930
    2289
    1542
    Hmmm....but what "mix" of bronze?
  16. #11
    Jul 2006
    8,964
    2149
    6217
    Quote Originally Posted by barbter View Post
    That I leave as an exercise for the student...
  17. Likes barbter, LKeithR, eKretz, AD Design liked this post
