steamandsteel
- Oct 21, 2017
- Wichita, KS
Hello,
I have a Mitutoyo Digimatic DRO Display, Code No. 982-537-1. It's seen better days - (damage not done by me) but the fact of the matter is it has worked and served me well. I had taken the unit off the machine to clean a few things on the machine. When I turned on the scale, seemed okay. Fired the machine up, and all of a sudden I lost my Y axis, and the display read E 3 across the display.
I took the box apart, cleaned and checked all the connections. Contact cleaner, etc.
Hooked X scale to Y port, works. X scale to X port, works.
This leads me to believe the Y scale is the culprit. I've attached some pictures, and am looking for advice on what to do.
1. It's a working system. Is it possible to buy an import 16" scale that is compatible with this unit? Looks like a serial connector
2. Given the condition, is it only a matter of time before the X or the box go out, and should I buy all new? If so, recommendations?
Thank you in advance..
