Molding urethane gaskets
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Nov 2016
    North Carolina
    145
    36
    69
    Default Molding urethane gaskets
    Anyone have experience molding resin? We were doing some product development work for a company, CNC machine stuff, and they mentioned needing a spacer and gasket to go with some of what we were doing. I happened to be experimenting with casting vacuum forming molds at the time and said we would give it a shot, and maybe make a sealing spacer out of flexible urethane. So I milled a low tech injection mold out of aluminum and shot the urethane in with a syringe.
    It worked, and now they need about 1,400 of them. Which is fine and all, but my prototype setup does not lend itself to mass production.
    The part is rectangular, 1-3/4"x3/4"x1/8" with some 2D features (not just flat that could be stamped out). Anything soft enough to seal I'm expecting to be too soft to machine, so I'm thinking molding is the only way to go? Anyone know different?
    My first thought is to find a recovering junkie that will happily sit and inject these molds for about three weeks. I don't think the quantity is enough to justify a "real" injection mold set.
    What's a good system for short run urethane molding? Some kind of semi-automated setup to speed things up would be great. I did some reading and most of the other posts seemed to be a few of larger gaskets where labor time wasn't so much an issue.
    Jan 2007
    Norfolk, UK
    19,897
    15338
    15612
    Water jet from sheet material?
    Dec 2005
    Waukesha, WI
    1,796
    438
    583
    Quote Originally Posted by Limy Sami View Post
    He said it wasn't flat and therefore couldn't be cut from sheet.
    I've done a fair amount of urethane casting. Never tried a syringe, sounds like a mess but whatever. I was always able to pour into a metal or even wood mold. Wood has to be coated with several coats of lacquer. Gosh I'd hate to do 1,400 of them. Sign up the recovering junkie and see if you can make 5 or 10 molds so he can do several at a time.
  4. Likes Thunderjet, LOTT, BugRobotics liked this post
    Apr 2019
    Arkansas
    1,304
    573
    494
    Quote Originally Posted by adh2000 View Post
    We so lots of casting here. What questions bdo you have specifically
    Sent from my Pixel 3 using Tapatalk
    Nov 2016
    North Carolina
    145
    36
    69
    It needs to be flat and a fairly accurate thickness on both side, it could be poured into an open top mold but the surface tension means that it doesn't come out flat, it's more bubbled up. Hence the syringe injection, and yes it's a mess.
    Jun 2015
    Colorado
    576
    1175
    241
    You can go somewhere like Protolabs to get a small run completed. May make sense for your numbers. You can send in your model and get a quote within a day or so on their website.
    Protolabs Part Upload
    Nov 2016
    North Carolina
    145
    36
    69
    Are you casting parts you can just pour the resin into, or injecting resin into a mold? Is your process automated at all? These are small gaskets, finished weight of these things are 1.25 grams, and the flange gets down to .015. Which it why we're injecting the resin, which is a slow manual process that I want to improve.
  9. #8
    Jan 2007
    Norfolk, UK
    19,897
    15338
    15612
    My mistake please ignore this post.
  10. #9
    May 2009
    Canandaigua, NY, USA
    3,019
    151
    1384
    I've done some of this kind of thing using silicones and resins from Smooth-On. Results have been great. You need a 2-part silicone mold, assuming the precision would be good enough. Can't imagine doing 1400 of 'em. Could you make a silicone mold with 5-10 cavities that you fill all at once? That would ease the pain a bit. See the videos at the Smooth-On site if you haven't done silicone molding.
  11. #10
    Nov 2016
    North Carolina
    145
    36
    69
    Quote Originally Posted by BugRobotics View Post
    I haven't tried Protolabs, but just for fun I ran it though Xometry and they wanted $91 a piece. Which is probably how as9100d is able to be buying planes and Haas's by the truckload...
  12. #11
    Feb 2010
    IN, USA
    259
    7
    271
    There's bound to be at least one small run rubber mold house near you. We've got 3 in our medium size town that do everything from one off prototypes to 10,000+ piece runs.
  13. #12
    Nov 2016
    North Carolina
    145
    36
    69
    Quote Originally Posted by Conrad Hoffman View Post
    I've done some of this kind of thing using silicones and resins from Smooth-On. Results have been great. Can't imagine doing 1400 of 'em. Could you make a mold with 5-10 cavities that you fill all at once? That would ease the pain a bit.
    I'm using a Smooth-On product, and you're exactly right about 1400 being a bunch to do by hand. The mold has three cavities, but because of the limited pressure we are filling the cavities one at a time. Some kind of high pressure injection system would be great, but since it's a time curing resin and not a melting plastic I'm not sure how it would work.
  14. #13
    Nov 2016
    North Carolina
    145
    36
    69
    Quote Originally Posted by Punkinhead View Post
    Not that I've found. We're in rural North Carolina, which is great in a lot of ways as far as low overhead and being generally left alone, but there isn't much in the way of industry. It's like a country song, if there's a traffic jam it's a tractor...
  15. #14
    Apr 2019
    Arkansas
    1,304
    573
    494
    Smoothon is way too expensive anyways. We use polytek here and we have some home made tools that do metered mixing under pressure for injection.
  16. #15
    Nov 2016
    North Carolina
    145
    36
    69
    Quote Originally Posted by as9100d View Post
    That's what I'm looking for! Is there any non-proprietary info on metered mixing under pressure you can share? The Smooth-On may be more expensive, but for the sizes we're doing now the cost of resin is immaterial compared to labor. Also for someone new to the process Smooth-On makes it easier to find what you need then PolyTek, but I'll give them a try if this continues.
  17. #16
    Apr 2019
    Arkansas
    1,304
    573
    494
    You would be surprised.... Polytek applications engineers would tell you which product to use, estimate part cost, and show you machines to use. That's how we learned.
    We go through about 200 gallons of 80a polyurethane per month.
    Google a machine called "minirim" from dispensingliquid.com
    That's what you will need, or we can quote the parts for you.
  18. #17
    Jun 2015
    Colorado
    576
    1175
    241
    Quote Originally Posted by LOTT View Post
    Haha, yea that is a tad high Molding urethane gaskets. Never tried Xeometry before
  19. #18
    Apr 2019
    Arkansas
    1,304
    573
    494
    Molding urethane gasketsMolding urethane gaskets xometry work is good for sure! Lately I've been dominating the stock market and buying less Haas and more dmg Mori machines.
  20. #19
    Dec 2005
    Waukesha, WI
    1,796
    438
    583
    Smoothon is a lot cheaper than Polytek. I’ve been buying the 16 lb kits from Reynolds Advanced Materials for $92. The same 16 lb kit from Polytek is $143.
  21. #20
    Apr 2019
    Arkansas
    1,304
    573
    494
    I'd give polytek a call, order via phone and email not their website.
