Monitor is squiggly when cold
Likes Likes:  0
Results 1 to 7 of 7
    Aug 2008
    San Antonio, TX
    112
    11
    Default Monitor is squiggly when cold
    Bridgeport Interact with a Heidenhain controller.
    My monitor is squiggly when it is cold outside. If its 42 degrees then I can barely read the monitor, its a blur of amber. Once it warms up the lines are more stable but still vary.
    Any ideas where to start looking?
    I did find a blown capacitor on the board and I replaced that but there was no change.
    Sep 2009
    New York
    108
    Quote Originally Posted by shanghyd View Post
    I'm guessing this is a CNC retrofit onto a Bridgeport. Is there any way to test the video board with a separate monitor?
    Mar 2009
    Centerville, TN USA
    338
    6
    I don't know if it's a LCD, but one of my shop monitors does the same thing when it's cold. I think I bought that LCD in 97 for $1300, and I guess it's just old tech. My new ones do just fine in the cold besides taking a little while to get fully bright.
    Jul 2009
    Cobblers Knob, IN USA
    1,100
    6
    If it's a tube, I assume you blew the dust out. Does it have a degauss button?
    Mar 2005
    Canberra, Australia
    592
    Electrolytic capacitors dry out over time.
    A good start would be to replace them all. Anything over 5-6 years old could be shot, depending on the make and how hot the environment.
    - Mike -
    Aug 2008
    San Antonio, TX
    112
    11
    The monitor (inside) case was very clean. No dust. No degauss button.
    It isn't a retrofit it came this way. I don't have another monitor to try.
    I'm going to try the capacitor route.
    The capacitors say "West Germany" on them so they are probably pretty old.
    Jan 2004
    Claremont, NH
    1,637
    9
    51
    I kind of glossed over this thread until today, when I arrived in my shop and some idjut left a pair of windows cracked open - the shop was 39 degrees this morning, -7 outside. All of my monitors seemed to object to being waken up on this morning, flat screen PCD and CRT type.... Seemed my older Anilam CRTs hated it the most and had the squiggles as well for about 15 minutes. Must be a standard problem in older type monitors (or then again, is the real problem having a shop at 39 degrees?)
    Note to self - put gobs of prussian blue on the window handles to catch the mangy varmit who is doing this on a daily basis........
