I’m fixing minor issues on a used No. 3 Moore Jig Borer before putting it in service. Checking with no power to it, everything that’s supposed to move without power is now moveable. One part moves too well. The right “x” table handwheel’s micrometer dial isn’t connected mechanically to the handwheel or its shaft. The dial spins freely with very little friction. The only difference I see between that handwheel assembly and the front one is that the freewheeling one has about a 1/16” gap between it and the disc forming the outer side shell of the housing. Front wheel has no gap. The 6 small holes around the circumference of the mike dial appear to contain stake pins, top surface of which is a conical cavity. I’d love to hear about an easy fix but if not will have to disassemble the mike dial housing. The 6 stake pins are all the same depth as those on the front wheel and none move down when tapped with a punch.
