Most efficient way to drill fork lift fork?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
    Feb 2012
    Los Angeles
    20
    Default Most efficient way to drill fork lift fork?
    Hello all,
    Putting aside the potential legalities in case of an accident (this is for personal use), what's the best (most efficient/cheapest/best) way of drilling a hole in a fork lift tip for a trailer hitch? Really would appreciate your tips and ideas as I haven't drilled forks before.
    Thanks!
    Sep 2005
    il.
    6,912
    49
    1431
    i would imagine it would have to be carbide
    Nov 2004
    Webster Groves, MO
    7,987
    2077
    3904
    I mounted a ball on the end of one of my forks to move a trailer and found that steering it was difficult with the forklift steering one way and the fork end going another. Removing the forks on my little NAMCO is easy, so I made a hitch with the ball just in front of the mast that replaces them. That steers easily.
    Bill
  4. Likes Red James, Scottl, pb1 liked this post
    Apr 2009
    AUSTRALIA
    408
    716
    77
    The company I just left machined fork tines regularly, Its hard stuff but machinable. Find a way to set it up on a drill press and use a strong HSS drill bit If its old dont thin the web... use plenty of cutting oil its even Tap-able
    Apr 2007
    Dublin Texas
    2,629
    1443
    927
    What Thermite said.
    i_r_
    Jan 2011
    Kansas
    759
    55
    61
    I took a torch to one of ours when I need to put a ball hitch on it. Sure it is ugly, but its fast.
    Jan 2010
    Indianapolis, Indiana, USA
    5,467
    2426
    936
    Magnetic drill with Morse taper capacity.
    Or a huge portable drill with Morse taper capacity.
    And a series of successively larger drills.
  9. #8
    Feb 2005
    tallmadge,ohio
    133
    14
    7
    Torch method is what we used.
  10. #9
    Jan 2007
    Norfolk, UK
    21,280
    16657
    17334
    A flat steel bar that lies across and clamps to both forks, places a hitch ball in the center would still leave one with the steering issue to get used to.
    But being centered, perhaps less so, as it is at least in line of sight.
    And no drilling of the forks themselves required at all.
    Bill
    + Another
  11. Likes SVE Performance, tim9lives liked this post
  12. #10
    Oct 2005
    21,381
    Quote Originally Posted by munruh View Post
    Yup, hot wrench.
    Use a heavy washer (larger than desired hole) as a template,
    comes out much nicer.
  13. Likes TFPace, oldbikerdude37 liked this post
  14. #11
    Dec 2009
    N. Calif.
    150
    10
    67
    I built a sleeve out of rectangular tubing, with a receiver tube welded on top.
    We use a three balled gazinta or other devices for moving a wide variety of trailers and other stuff.
    A come-along between a carry handle and the backrest keeps it on the fork.
    Very flexible and quick to install.
    No hole in fork to make the safety people happy.
    K
  15. #12
    Aug 2004
    Winchendon, MA USA
    804
    231
    I used my mag base drill 1/4" pilot drill, then 3/4" thru no problem.
  16. Likes Polaraligned liked this post
  17. #13
    Nov 2010
    Oregon
    297
    41
    65
    I got a real chuckle out of that comment. I am continually amazed by the mental acuity demonstrated by members of this site as common and everyday. But backing a trailer is found to be "difficult"?
  18. #14
    Dec 2004
    uk
    14,046
    4552
    6723
    Thermites approach works in three places i have dealings with, it does take some thinking, not exactly obvious but that extra swing and side shift really opens up a whole bunch of options!
    Holes in fork tines is a expensive H&S fine and new forks here, (before you ask if you then shorten them they insist there retested, which no one will do!) clamps are always available cheaply and often to hand in engineering!
  19. #15
    May 2002
    South Central PA
    14,585
    2821
    4315
    ... yep.. if you WORK it right, the self-same rig can even be made to fit the front-bumper of 'some' pickup trucks. Or? wotever other 'MHE' one might have at hand, not just the one FL.
    I've encountered bolt on front hitch receivers for this use and for pipe racks, etc.
    If I were to build one I'd offset it to the passenger side so I could see down the side of the trailer while in the driver's seat.
    OK, I think we're officially off topic.
  20. #16
    Oct 2005
    21,381
    Try spotting a large boat on a trailer next to a wall
    for winter storage, on a Waldron articulated loader
    with a ball in the bucket.....
    And yes, they insisted it be closer than 1' from the wall
    (gotta stuff 'em in to make any money)
    I find the "hole in the fork" most handy for a clevis
    to attach a chain or wire rope sling
  21. #17
    May 2007
    Central Texas, West and North of Austin
    1,627
    178
    532
    Talking
    Call it 'Old Age and Treachery', but I'd just drill the bar left, right AND center... pop the ball in where the task needed it.
    Or .. always wanted to have three balls... so ..for-sure NOW we are 'off-topic'.
    Bill
    Three? Wha for? Ballast?
  22. #18
    Jan 2011
    Miami, Fl
    239
    211
    23
    The third as a "SCHPAAAARE"!
  23. #19
    Jan 2012
    Connecticut
    72
    9
    6
    As I see it there's two ways:
    A: Torch cut a hole.
    B: Rent a magnetic base drill with an anular cutter and blast it one shot.
  24. #20
    Sep 2006
    South Central Ky
    44
    5
    9
    PLASMA CUTTER, if ya got it , gives a cleaner hole , otherwise smoke wrench it , time is money
