My 7.5 hp Baldor motor is used as an idler in an RPC. It had Zerk plugs in a hole over each bearing. The motor was new old stock when I got it and was noisy and overheated after some 15 minutes at first.
I disassembled it and discovered that it had open precision roller bearings on each end. They were caked with old, dried grease.
Some research on the Baldor website said that the proper grease was Mobil PolyRex EM. It's blue and comes in a tube. I bought a tube on Amazon and, after cleaning out the grease passages and lubricating the bearings and plugging the holes with small hex plugs, I reassembled the motor using PolyRex grease. It now runs quietly with no overheating.
Since the motor has open bearings, any excess grease would have gone directly into the windings with disastrous results.
Baldor says that the PolyRex is good for 1,000 hours between re-greasing. I added a Hobbs meter and I'm up to 200 hours or so now with no problems.
I
