kb1cjp
- Nov 14, 2012
- Connecticut
I am repairing a 3 phase geared motor that mounts with the shaft vertical, and the gearbox is on top. The lower bearing was making a chirping/squealing noise. Took the motor apart and found the lower bearing was stiff and had been spinning in the aluminum housing. There is a thin spring washer in the bottom of the housing as well that pushes up on the bearing. The bearing is 40mm OD 17mm ID, and 12mm thick.
My question is, what are my options regarding the housing being worn. I assume because of the spring washer the bearing should kind of float in the housing, but it should not spin. lock tight, epoxy, bore out housing for larger bearing, bore out and install a shim, other ideas?
Thanks for your help!
Brian
Brian
