Mounting a rear toolpost, Harrison M300
Likes Likes:  0
Results 1 to 5 of 5
    Apr 2004
    Modesto, CA USA
    7,064
    1191
    Default Mounting a rear toolpost, Harrison M300
    I have a spare BXA toolpost I would like to mount on my Harrison m300 lathe. Some folks make a fancy dovetail adapter so no holes are drilled in the cross slide. Is there any reason not to just drill a mounting hole and thread it into the cross slide. Of course watching out for oil passages, nuts and cross screw etc.
    Would this be strong enough so the casting will not snap. This is a 13inch lathe with 3 horsepower so it has enough power to do some damage.
    Bill D.
    https://www.ebay.com/i/183766853439?...SABEgKucvD_BwE
    Mar 2009
    Brunswick Oh USA
    4,543
    5085
    2711
    Bill,
    As far as I can see, that CS has a dovetail. Here's my Sheldon with two tool posts. Sometimes I snug them up for a lot of cutting off or whatever, or slide it way to the back and out of the way. Looks to be strong enough for what a 13'' is designed for.
    100_1944_zpsggwguhql.jpg Photo by rbehner | Photobucket
    Apr 2004
    Modesto, CA USA
    7,064
    1191
    That makes sense that using the dovetail I can slide it back out of the way. Now I have to figure out the dovetail angle and find an endmill to match. The main ways are oddball I think 70 degrees. They are not 60 or 45 which. would be easy to find a match.
    Bill D
    Sep 2007
    Israel
    70
    12
    You can make the dove tail part to clamp with screws on side of a plate, that's way you can lock the plate and also make simple dove tail side bar that can be milled with regular mill by tilting or angled vice etc...
    Apr 2004
    Modesto, CA USA
    7,064
    1191
    Quote Originally Posted by Yan_b View Post
    That idea sure saves a lot of time and material.
    Bill D.
