Mounting a small chuck on L0 backplate
Results 1 to 3 of 3
    Jun 2012
    Chicago, USA
    1,462
    11
    115
    Default Mounting a small chuck on L0 backplate
    Hi all,
    I have to mount a 5" 6-jaw lathe chuck on an L0 backplate. The chuck has threaded mounting holes close to the rim, designed to be screwed into from the back.
    Because of the small size of the chuck, the necessary through holes in the backplate would eat into the taper mount portion of the backplate.
    Edit: ignore the existing holes in the backplate, it came that way from the factory. The needed hole pattern is center punched and marked with black sharpie dots.
    I see 2 ways around this:
    1) use an intermediate spacer the same diameter as the backplate, bigger than the chuck body
    2) drill through-holes in the chuck body and screw into the backplate from the front.
    I would prefer to do 2), as it avoids a bulky setup and reduces overhang from the spindle. But, there's not much room to get those through-holes into, and the countersink holes for the SHCS would actually exceed the outer diameter of the chuck - not ideal.
    Is there a better solution I'm too dumb to see?
    Lee
    Sent from my SM-N960U using Tapatalk
    Jan 2005
    Victoria, Texas, USA
    4,115
    2333
    1046
    You can modify the chuck with thru holes to the face, so you can use longer socket head cap screws thru the chuck to the back plate. I have 5" 3-jaw chuck I did that to last year. You can also mount a sub plate the 5" chuck with a flange large enough to install socket head cap screws thru to the back plate. Provided the back plate is large enough to drill and tap new holes to accept the screws. Ken
    Feb 2006
    Indiana
    13,013
    698
    3965
    3. Get a Pratt Burnerd Setrite 6" 6-jaw chuck. It has the mounting screw heads on the front and you get an adjustable chuck. But you have to have a 3.12 inch boss on the front of the adapter that the four adjusting screws bear on, which may be a bit small for the through hole of the L0 adapter.
    https://www.prattburnerd.com/detail....C&m=SC-253-263
    Larry
  4. Likes 4GSR liked this post
