Moving heavy equipment the hard way
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Jun 2008
    Yukon, OK
    534
    12
    65
    Default Moving heavy equipment the hard way
    I had to move my 25" Standard Lodge & Shipley approx. 50 feet to our main roll up door so that it could be winched onto a rollback and taken to the new owners shop. It weighs about 15k lbs and had to be manuvered a bit to get around the 2 post lift and metal rack.
    I built an expedient attachment to turn my 32 ton bottle jack into a toe jack. It is nothing fancy, just heavy scrap plate and a small chunk of heavy pipe that just happened to fit the ram perfectly. It didnt take long to make and it did the job with no problem.
    I bolted a set of 1/2" plate ski's under the base at the headstock and a pair of 3x3 angle iron skis at the tail end. I used (2) 1" solid steel bars at each end to roll it across the floor. The majority of the work was done with a 5 foot pry bar and a 10 lb sledge.. a roughnecks best friends
    I took a video to show how much of a pain in the ass this process is.. especially when you are doing it all by yourself.
    YouTube - ‪Moving a 15,000 lb. lathe by hand‬‏
    Dec 2004
    uk
    14,046
    4552
    6722
    Next time sweep the floor first (makes a world of difference), buy a cheap cum along winch (1/2ton of real pulls enough) Then you only have to crab it around the obstructions with the pry bar. Alternative just pull it with a verichal. Even a small truck will easily pull it along on rollers.
    Lifting the end every jerk with the crow bar is really doing it the hard way!
    Sep 2005
    il.
    6,903
    47
    1422
    yup
    first payroll deduct item i ever got
    saves my ass all the time
    pulled an ACME RA-6 (30k screw machine) out from behind 2 others slick as snot with a 3/4 ton years ago with energy to spare
    Oct 2006
    Mediapolis, Iowa
    1,712
    364
    387
    the important part is you did it.
    Who cares if it was the hard way.
    I have to move a 8000 lbs machine about 20 feet. It's on 6" high wood block right now that sit on hard packed gravel (not sure how hard packed).
    I have to move it the 20 feet then lift up onto a concrete landing that is 7-8 inches higher than the gravel.
    I'll probably end up doing it the hard way too.
    Feb 2005
    Ohio
    1,225
    1507
    228
    The easiest way is to hand your rigger a check!
    Mike
    Mar 2009
    Brunswick Oh USA
    4,692
    5450
    2830
    15,000 pounds? I may be wrong, but it doesn't look to be that heavy.
    I thought I was wrong once, but I was mistaken!
    Nov 2010
    Oregon
    297
    41
    63
    I'll keep you in mind in case I ever build a pyramid
    Jan 2010
    Indianapolis, Indiana, USA
    5,467
    2426
    935
    There should be a national holiday for Masden.
    Ratchet pullers don't collect dust, they wear out.
    Jun 2008
    Yukon, OK
    534
    12
    65
    Quote Originally Posted by adama View Post
    The floor was swept very well in the path of the lathe. I wasnt able to use the forklift that I would normally use to help push something on rollers. I had to get it done that night... so I did
    Jun 2008
    Yukon, OK
    534
    12
    65
    Quote Originally Posted by mister honey View Post
    Mike
    Definitely the easy way! Not an option on this move though.
  11. #11
    Jun 2008
    Yukon, OK
    534
    12
    65
    Quote Originally Posted by Ray Behner View Post
    It has a fairly short bed, but it is very heavy. The headstock and tailstock are massive and then theres the 20 hp motor hanging off of the backside.. I was told 14-15k lbs.
    Andrew
  12. #12
    Jan 2005
    Victoria, Texas, USA
    4,481
    2915
    1208
    You know its heavy when it shakes the camera!
    Andrew, If you don't mine saying, who's the new owner?
  13. #13
    Nov 2007
    Port Coquitlam BC Canada
    695
    11
    262
    Default Moving monarch
    I like to do it this way .
    Collector
    Attached Thumbnails Attached Thumbnails may-2011-monarch-lathe-002.jpg   may-2011-monarch-lathe-004.jpg
  14. #14
    Aug 2006
    Hesperia, SoCal
    4,362
    987
    655
    Thanks Jager, great illustration.
    No doubt there will be lots of links to it over the years, "whuddaya' mean it weighs 1,500 pounds, check out Jager with 10 times that, doin" it the hard way too!"
    Quick poll, anybody not jealous of Collector? ....in a good way...
    2nd question, which one's the skinny one, Jager or Collector?
    Bob
  15. #15
    Feb 2011
    Pensacola, FL
    1,307
    154
    810
    Jager, the few times Ive ever had to move some equipment, all I had was two big pinch bars, and some rollers underniether the machine. Its slow and labor intensive, but In my small shop thats all I had to get the job done. It works.
  16. #16
    Jan 2011
    Miami, Fl
    239
    211
    23
    Angry thanks!!!!!
    Quote Originally Posted by collector View Post
    Collector
    Thanks, Rub it in ! Mere ground based mortals, such as myself, are stuck with forklifts and prybars.
  17. #17
    Jun 2008
    Yukon, OK
    534
    12
    65
    Quote Originally Posted by 4GSR View Post
    It definitely shook the floor pretty good a few times!
    A fellow from Goliath Manufacturing here in Houston bought it. Going to use it to build modules for oil field mud pumps among other things.
    Collector
    I would LOVE to have that option. Your shop is amazing.. I drool every time you post up pictures
    Andrew
  18. #18
    Jun 2008
    Yukon, OK
    534
    12
    65
    Quote Originally Posted by Robert Campbell Jr. View Post
    Bob
    lol.. nice Bob
  19. #19
    Mar 2006
    Arizona now, raised in the mountains of Milw. WI
    213
    23
    26
    Bob
    I'm not jealous of anyone. Been doing it the same way for 50 years and I'm just as skinny as Jager. I wonder why my back hurts?
    Best wishes to ya'll.
    Sincerely,
    Jim
  20. #20
    Apr 2006
    Manchester, England
    9,088
    1480
    6032
    Quote Originally Posted by Jager View Post
    Andrew
    !5,000 lbs is approximately 7.5 tons in our money. That's a lot for a short centre lathe. I moved an Herbert 9C-30 the other day, they're a big turret lathe with a big motor and they weigh a fair bit less than that. Just going off the photo I'd have said 10,000 maximum. Regards Tyrone.
