Mr Deburr stinks
Results 1 to 15 of 15
    Feb 2017
    New York
    162
    15
    66
    Default Mr Deburr stinks
    The machine is awesome. The cleaning compound that I got with it stinks after a short period of use to the point of being offensive, people that come in the shop comment on it and I have to keep the door open when using it.
    Mr Deburr 300DB ** STARTER KIT FOR ALUMINUM plus STARTER KIT FOR STEEL
    Anyone suggest another concentrate to use?
    Jan 2007
    Norfolk, UK
    21,388
    16758
    17529
    Have you tried dishwashing liquid detergent?
  3. Likes gary-sc liked this post
    Feb 2017
    New York
    162
    15
    66
    Quote Originally Posted by Limy Sami View Post
    I haven't tried anything other than what came with the unit in the link. Looking for guidance and will consider what you suggested.
    Oct 2005
    22,565
    Are you supposed to re-charge with new every so often ?
    Much like coolant.
    Feb 2017
    New York
    162
    15
    66
    Much like coolant.
    I have done that. I just moved into my new shop and cleaned the entire unit including the pump. After 1 use it smells.
  7. Likes digger doug liked this post
  8. #6
    Jan 2019
    Arizona
    1,292
    112
    522
    Quote Originally Posted by IWUP View Post
    if the bucket of water sits for longer than a day or 2 it will stink, your suppose to change the water out all the time. has nothing to do with the soap, everything to do with alum dust mixing with water, just like coolant.
    I use the vt77 every single day for the last 3-4 years on alum / sometimes I change the water 2-3 times per day not because of the stink but because of the powder from the synthetic media I use. you really need to use CLEAN water.
    on ceramics with stainless I do the same.
    1 to 2 oz per cup is all you need.
    most dish soap will leave a film on parts as well as some other cleaning soaps made for tumbling.
  9. #7
    Dec 2013
    South Charleston, WV
    36
    46
    14
    I have used/tried almost every type of compound/soap/etc. when tumbling. For the initial stage w/plastic media I use Simple Green concentrate at a ratio of 1 cup/5 gallons and use a flow through system. The solution never stinks. I have also found that I get better cutting action (reducing cycle times) with SG as it does not produce a slimy/soapy film on the media which inhibits the cutting action. YMMV
  10. #8
    Oct 2014
    Arkansas
    291
    70
    It is a vibratory finisher. You use vibratory finishing compound. You mix it 1 oz to a gallon of water. Then you run 1 gallon per cubic foot per hour into the machine. It drains out the bottom of the machine. This keeps the parts and media clean. (And it will never stink.) I've been selling/using this stuff since 1978 to 1,903 current customers.
    Vibratory Finishing Mass Finishing Ball Burnishing Deburring Media Compound Equipment
  11. #9
    Jan 2019
    Arizona
    1,292
    112
    522
    Quote Originally Posted by Delw View Post
    1 to 2 oz per cup is all you need.<<<<<<<<<<<<<< Sorry thats 1-2 oz per gallon
    Had a brain fart above
  12. #10
    Feb 2017
    New York
    162
    15
    66
    Quote Originally Posted by rickseeman View Post
    Based on what you said should I have 2 buckets, one with the clean solution and one under the drain? I didn't consider that as an option.
  13. #11
    Oct 2014
    Arkansas
    291
    70
    Yes, the vibratory finisher should be hooked up to a drain. Most people, depending on volume, drain the machine into a sediment tank to allow settling, and then run the hose off the other end to a drain.
  14. #12
    Feb 2017
    New York
    162
    15
    66
    Thanks for the input, I appreciate it. I am currently recirculating the liquid and will try the 2 bucket approach.
  15. #13
    Jan 2007
    Norfolk, UK
    21,388
    16758
    17529
    I get them
  16. #14
    Oct 2005
    22,565
    I get them
    You don't say....
  17. Likes lucky7 liked this post
  18. #15
    Jun 2004
    828
    779
    176
    You don't say....
    C & H was the best in the Nederlands there were called Caspar and Hobbs
  19. Likes digger doug liked this post
