I am going to need to supply a locking ring with some other parts that need to be built, and the locking ring currently has incomplete specs on the drawing for a multi-start thread. I need to get complete spec for the thread from my customer if possible; my guess is they will just want to send me a sample... In any case:
1. Multi-starts have a TPI callout typically, I think. Does the TPI spec for multi-start represent the thread count for all threads included, for example, a 4-start thread at 16 TPI is essentially a 16-pitch thread run at 4 TPI setting, then the 16 TPI spec adds all the separate threads in the pitch count?
2. Is a lead angle ever required for multi-start spec?
3. Seems like the easiest way to make this on a conventional lathe is using the same thread dial number/mark every time and indexing the compound at zero degrees by the TPI number. (?)
