Bill D
- Apr 1, 2004
- Modesto, CA USA
Trying to find some 12mm 1.75 hex head bolts that are threaded clear up to the head. Most I see are threaded about half way up then solid round shaft to the underside of the head. Is there a special name for the ones that are threaded all the way. If I had a die I could thread the extra bit but since these are leveling feet for my lathe I can not single point them on the lathe right now. Easier, and probably cheaper, to buy them anyway.
Bill D.
PS: A tip: I am going to solder a washer under the head so the washer stays in place to stop a wrench from falling down off the head. The washer will not actually touch anything and is not really needed. Of course the hold down bolts will have washers that float and rotate like any normal washer.
Forgot to say only need four, about 60mm long. I could buy metric all thread and weld on 3/4" nuts but for 4 bolts seems like some work. I will have to check the local bolt store this afternoon and see what they have in stock.
Bill D.
