Name this Fastener!
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jun 2019
    AUSTRALIA
    7
    Talking Name this Fastener!
    If you can!
    Spec:
    16mm hex, with 4mm hole and circumferential channel for split pin
    8mm dia x 19mm deep hole down from top of hex head
    14mm dia shoulder, flattened to 11.5 mm
    8mm dia x 25 mm long shaft, internally threaded with M4 x 0.5 mm
    good luck!
    Bonus points for identifying the item for sale somewhere
    Norfolk England
    1,829
    2194
    1340
    Quote Originally Posted by good.darts View Post
    If you can!
    Spec:
    good luck!
    Absolutely no idea but I'm proud to say that I didn't make it. I would have had to work hard to get finishes and burrs like that.
    Jan 2007
    Florida
    1,078
    129
    396
    long time since i've seen one of those.
    "hexagonally inverted steloid camsnapper"
    Jul 2005
    Cottage Grove, MN 55016
    7,387
    3977
    4405
    I believe it's a Internal thread "Snap Screw or it maybe a snap nut" I used to bolt down hardened plates and we wold torque the bolt down until the top hex broke and then we would grind, file the rough surface left. It was probably made for a special job. I have never seen an internal one. It might be called a snap nut?
    Shear Snap Off Nuts Bolts & Fasteners | Fastenright Ltd
    Oct 2012
    NE Ohio USA
    598
    112
    221
    Looks like a transverse rod connector of some kind. Not sure of source though.
    Best Regards,
    Bob
  6. Likes good.darts liked this post
    Jan 2007
    Norfolk, UK
    18,104
    13631
    13567
    That's a splonge valve trunkling guide cross pin, from a Mk 37 B.2 Turboencabulator (Type - Southern Hemisphere)
    Sep 2012
    NW Iowa
    230
    126
    190
    Quote Originally Posted by Limy Sami View Post
    Also used on the pre-war Essex Tri-Directional.
  9. Likes David Ferguson liked this post
  10. #8
    Jun 2012
    Michigan
    4,373
    3959
    2589
    Was it made from billet?
  11. Likes Hodge, digger doug, Yan Wo, Marty Feldman liked this post
  12. #9
    Mar 2011
    SWITZERLAND
    954
    117
    382
    That’s a bolt.
  13. Likes SIP6A liked this post
  14. #10
    Feb 2014
    Sunny South West Florida, USA
    2,406
    9743
    2864
    His name is Fred.
    /thread
  15. Likes Mud liked this post
  16. #11
    Sep 2010
    Vancouver Canada
    857
    612
    295
    Quote Originally Posted by Mtndew View Post
    I doubt it; judging by the zinc coating it's totally a Grade 5 Home Depot fly by night contractor special, hence the burrs too. Limy Sami might be right it's off a turboencabulator but if so it's one of these modern not nice to work on units, not the elegant brass and glass turboencabulators of yore.
  17. Likes Mtndew, Limy Sami liked this post
  18. #12
    Jun 2006
    Near Seattle
    4,623
    2828
    1213
    That's what an aged sex-bolt looks like after excessive time from being upside down (in the southern hemisphere....)
  19. Likes sfriedberg liked this post
  20. #13
    Jan 2007
    Norfolk, UK
    18,104
    13631
    13567
    Quote Originally Posted by R. Dan View Post
    Was it? …………...blimey, I never knew that,
    Cheers mate - I owe you one.
  21. Likes R. Dan liked this post
  22. #14
    Norfolk England
    1,829
    2194
    1340
    You might well owe him one,he won't get it. OK sorry, I'll make a brew.
  23. #15
    Jan 2007
    Norfolk, UK
    18,104
    13631
    13567
    Bloody kids
  24. #16
    Aug 2008
    Paso Robles, CA
    134
    21
    16
    Custom bolt -- to customer specs.
  25. #17
    Nov 2003
    Beaumont, TX, USA
    4,727
    160
    1400
    Name it? OK, lets call it a squack.
    But I really don't it even deserves a name.
  26. #18
    Oct 2010
    Oregon
    4,903
    3932
    1768
    Does the internal threaded go all the way down to the cross hole? If so, I'd guess it's some form of electrical binding post for fastening wires.
  27. #19
    Oct 2010
    Moscow,Idaho,USA
    1,043
    1195
    459
    It's a wrench to open a can of spam.
  28. Likes digger doug liked this post
  29. #20
    Jun 2016
    New York
    1,294
    645
    555
    Isn’t that a machine screw thread Sammy rod hanger ? Any industrial supply such as Graingers
    Prob not metric but just Loose inch threads ( or could be metric, just saw you are down under)
    Ps, not a joke reference to you limey! Google Sammy rod hanger bolt!!
