Name this Fastener! - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Jun 2019
    UNITED ARAB EMIRATES
    8
    Guys thanks for sharing such knowledge with us.
  2. #22
    Sep 2015
    Tennessee
    472
    240
    360
    It's a half-ass bolt. That's because whoever designed whatever it goes in did a half-ass job. There's almost never any need for something that complicated that couldn't be solved with a better design job.
  3. #23
    Oct 2005
    13,789
    Quote Originally Posted by good.darts View Post
    If you can!
    Spec:
    16mm hex, with 4mm hole and circumferential channel for split pin
    8mm dia x 19mm deep hole down from top of hex head
    14mm dia shoulder, flattened to 11.5 mm
    8mm dia x 25 mm long shaft, internally threaded with M4 x 0.5 mm
    good luck!
    Bonus points for identifying the item for sale somewhere
    Quote Originally Posted by 4squarelogicseo1 View Post
    Uhm..."Tag Team Spamming" ?
    or "Maybe you two want to get a room"
  4. #24
    Jun 2019
    AUSTRALIA
    7
    Thanks everybody for the serious input and ‘avin a larf with this fun topic!
    splonge valve trunkling guide cross pin, from a Mk 37 B.2 Turboencabulator (Type - Southern Hemisphere)
    We use to have those down here, but stopped making them when we got funny looks or hung up on…
    Does the internal threaded go all the way down to the cross hole
    No, it doesn’t go through
    Snap Screw or it maybe a snap nut
    hexagonally inverted steloid camsnapper
    Like the sound of those but couldn’t seem to back it up on google
    machine screw thread Sammy rod hanger
    Would the split pin hole need to be threaded?
    transverse rod connector
    I believe this is the intended purpose Bob, but was not the application I found it being used for (see below)
    Custom bolt -- to customer specs
    It was probably made for a special job
    Yes, probably. Ok so these bolts were being used as axles for Montblanc 2-wheel roller luggage – one bolt for each wheel. The shoulder slotted neatly into a plastic housing, supporting the whole wheel/axle unit and preventing axle rotation. The shaft of the bolt supported the two anti-friction bearings in the wheel (poorly, ~0.3 mm clearance on shaft), and the M4 x 0.5 took a torx screw which held the wheel on.
    There didn't seem to be any purpose to the hex head, split pin hole and channel, or the 8mm x 20mm hole into the head. So, as I said, I don't think this was the application it was designed for.
    I'm proud to say that I didn't make it
    ditto
    Thank you all
  5. #25
    Jun 2019
    AUSTRALIA
    7
    ditto
    Thank you all
  6. Likes michiganbuck, n2zon liked this post
  7. #26
    Nov 2018
    Michigan
    176
    78
    99
    No tag-team room needed. Dude just picks random threads to drop a meaningless line about sharing knowledge, look at all his other posts. Only time will tell when he thinks his post count is high enough to activate "Phase 2" of the master plan.
  8. Likes TeachMePlease, digger doug liked this post
  9. #27
    Dec 2008
    Vt USA
    6,547
    703
    2197
    ditto
    Thank you all
    So it's not a fastener, it's an axle. And is held in place by a legit fastener.
    I hate misleading thread titles.
  10. Likes lucky7 liked this post
  11. #28
    Jun 2019
    AUSTRALIA
    7
    It is a fixed axle in that application, however appears to be much more like a bolt or coupler/connector, hence the use of fixing in the thread title
  12. #29
    Dec 2008
    Vt USA
    6,547
    703
    2197
    No! You did NOT use the term "fixing" in the original post. The word used is FASTENER. Learn the difference!
    Weasel click bait ...
  13. #30
    Jun 2019
    AUSTRALIA
    7
    Yes you're right, I posted in a rush late last night.
    But seriously, is everybody on this forum so welcoming to new members?
  14. #31
    Jun 2012
    Idaho
    3,101
    1708
    2033
    So what you selling ?
  15. Likes digger doug liked this post
  16. #32
    Jun 2019
    AUSTRALIA
    7
    Quote Originally Posted by jrmach View Post
    Is that a serious question?
    I want to find a better version of the same bolt for my customer, where there's much less clearance between the shaft and the bearing. I thought rather than just ask for that, especially as a new forum member trying to leverage knowledge before having really contributed, I could ask it in a fun way.
    Even so, not overly impressed with the reception. You guys been burned by people trying to sell things?
  17. #33
    Oct 2005
    13,789
    Why didn't you !
    Try making a hand sketch !
    and posting it in the !
    "Manuf resources Section" !
    https://www.practicalmachinist.com/v...ring-resource/
    Eh ?
  18. #34
    Jun 2019
    AUSTRALIA
    7
    I think everybody contributing to this thread should stop for a moment and have a think about how we treat each other. Is this how you would like to be treated?
    We all get a say in what we think society should look like, and I personally want to live in a world where we help each other out and learn from each other. Surely that was/is the intent of this forum?
    I kinda like the down under jokes, but can we all be better than sniping or writing other negative comments
  19. Likes npolanosky liked this post
  20. #35
    Oct 2005
    13,789
    Awww....gonna take your ball on go home ?
    Please look in the mirror sir.
  21. #36
    Jan 2006
    Angier, North Carolina
    2,513
    995
    887
    Good.darts, welcome to the forum. Sorry that you got a bit singed in the process ... that often goes with the territory in a free-wheeling forum of machinists, but not always, and it is rarely clear why one thread goes off the rails while another stays on topic.
    BTW, I thought the complaint about this being an axle rather than a fastener was made in jest ... ? But as always, hard to tell in the "flat" medium of text on a screen.
  22. #37
    May 2002
    South Central PA
    13,354
    2116
    3316
    Quote Originally Posted by BoxcarPete View Post
    "seo" in his name is a dead giveaway.
  23. Likes digger doug liked this post
