Helping a friend repair a Nardini gap bed gear head lathe.
Upon getting it set up and running the lower gear box locked up. The lower gear box cover was removed and discovered a gear missing a few teeth , missing fork , spacer and someone put a couple zip ties on the shaft to hold the gears in place.
He is trying to source the gear ( 22 or 23 tooth) and looking everything else over.
One of the selector shafts is really hard to move , its indicated by the arrow in the pic.
Does anyone know how that gear shaft is removed ?
The manual show nothing indicating any set screws or pins holding it.
Looking at the gear head that is on the opposite side of the aluminum selector knob the shaft looks like its suppose to go straight thru into the gear case to be removed. I shot some Kroil on the shaft but there is a lot of O ring residue or sealant on the shafts. Only one is hard to move , the other are very smooth.
Its a nice lathe and was easy to get up and running on a VFD.
Hopefully the needed gear is not too much damage cost wise.
