dazz
Stainless
- Aug 20, 2006
- New Zealand
Hi
I ran my Nardini MS350 lathe for the first time today.
I hear a knocking sound at higher rpm. I am reasonably confident that the noise is coming from the oil pump. The sound is consistent with a weak or broken return spring in pump allowing the eccentric driven pump plunger to launch and then bang as returns. The oil pump is still pushing a lot of oil up to the sight glass.
I can't imagine that Nardini of the time (probably around 1970s) allowing the oil pump to knock. Am I wrong?
Later versions of the Nardini probably use the same oil pump. Is a broken/weak pump spring a common problem?
Getting the pump out to replace a spring looks difficult. It is buried in the bottom of the head stock under the spindle.
