Nardini or Victor lathe?
Results 1 to 16 of 16
    May 2007
    Ga
    31
    Default Nardini or Victor lathe?
    I've been looking for a decent sized lathe, and have come across two potential candidates. The first is a Victor 1630, and the other is a Nardini-TT 1230 E. Both look to be in about the same condition, except the Victor comes with a little more tooling. It has both the 3 & 4 jaw chucks, as well as a collet system, whereas the Nardini only has a 3 jaw chuck. The real positive with the Nardini is its set up for single phase 220v, with the Victor being a 3-phase 7.5hp motor. I know its possible to run the Victor with a converter, but I am not sure I will have enough power...looks like the phase converter will need at least 50-60a. The other option would be replacing it with a 7.5hp 240v motor, but that will likely add a minimum of $500 to the cost.
    Before I even consider that, is one necessarily any "better" than the other. My understanding is the Victor is Taiwanese, with the Nardini being from Brazil. Both will present challenges as far as replacement parts are concerned, but that is pretty much the same with a lot of the older imports. Is it just a matter of whichever one is in better condition? The Nardini will likely be around $1k cheaper ($2k vs 3k), is already set up for single phase, and is probably 1k lbs lighter.
    Any suggestions?
    Jan 2011
    North Central Arkansas
    141
    5
    42
    I think you are mistaken about the converter. I had a 21 inch Colchester that ran off a 15hp converter powered on a 40 amp circuit.
    I have a Nardini 1230E that now runs off a 7 1/2 HP phase converter fed on a 30 amp circuit. Never had a problem with either converter.
    May 2007
    Ga
    31
    Interesting, looks like I may need to do a little more research on the coverter.
    How do you like your Nardini?
    Apr 2009
    Beaver County Alb. Canada
    1,810
    522
    883
    Victor is still in buisiness, most parts can still be had .
    Nardini parts are hard to find.
    Victor Machines | Lathes, Mills, Drills, Grinders, Bandsaws | CNC Machine Tools
    Apr 2006
    Manchester, England
    7,778
    1048
    4715
    All other things being equal " Victor " every day for me.
    Regards Tyrone.
    Sep 2006
    Stillwater, Oklahoma
    1,220
    73
    616
    I think the power availability (max amps) and then the convertor sizing would relate to the kind of work you would do. Maximum current draw would only happen when taking off maximum material/time. If you're mostly doing modest work you could get away with theoretically insufficient power. If you were running from a smaller VFD it should flag a problem and cut out. If you're using another route for 3 phase (home grown large motor rotary) you could fuse it for your actual availability. And of course your breaker box should tell you if you ever cross the line.
    Jul 2011
    Brusly, LA
    692
    19
    272
    I have a victor 16x60 with the 7.5 motor. My RPC runs on a 50 amp circuit only because my whole shop is 50amp but IM sure it could run on a 30. I have a home built 10hp rpc btw.
    Victor is still in business, parts can be had, and its a solid machine.
    The guy I bought it from replaced it with a 20" nardini. Says he never should have let it go.
    Mar 2002
    dallas,tx
    2,454
    489
    428
    No experience with Nardini, but we have a 1630 Victor in our shop and it has been a trouble free, accurate, solid piece of machinery for the last 30 yrs.
    Apr 2007
    Dublin Texas
    2,576
    1402
    909
    They had a nardini in the shop but got rid of it before I got here. Traded it for a monarch.
    have fun
    i_r_
    Mar 2007
    Milwaukee
    391
    339
    180
    I've run both machines, id say the victor is a superior machine. The headstock was smoother with a better finish potential.
  11. #11
    May 2007
    Ga
    31
    Here are a few pics of the Nardini...
  12. #12
    Jan 2011
    141
    5
    42
    Quote Originally Posted by Jason280 View Post
    I got my Nardini as a broken production machine. Lots of wear on ways, bad spindle bearings, and shifting issues with apron. I just finished with the repairs and refurbish but havo only done small, quick jobs. All said, I have run more pleasing lathes.
  13. #13
    Jan 2006
    Aberdeen, NJ
    209
    34
    Nardini lathes were rather marginally built machines. Alot of them seem to have problems with cracked gibs especially in the compound. Victors have been around along time and most people have been pretty happy with them. Fairly well built and parts are available from Fortune machinery in NJ.
  14. #14
    Sep 2010
    Vancouver Canada
    825
    586
    286
    We have a Victor 1118DCL Toolroom lathe, which is an obvious Hardinge copy, and it's a nice machine that does exactly what you'd expect.
  15. #15
    Dec 2008
    Vt USA
    6,729
    667
    2131
    Nardini was a cheap machine from the start.
    If you want a HSM machine, have at it. If you want a tool that returns a profit on your efforts, choose the Victor.
  16. Likes Tyrone Shoelaces liked this post
  17. #16
    Sep 2005
    il.
    6,600
    29
    1204
    I like victor
    English speaking support in New Jersey
