Need 2 Strips of Low Friction Material
Robere210
Apr 4, 2011
Missouri
I'm making a kinetic log splitter using 5 Chevy 235 flywheels spinning on a 1" shaft. The motor is an Army surplus 2-cyl 9 h.p. motor. There is a pinion gear on the shaft that drives a rack that pushes a sled 26" down a 6" wide H-beam. The sled is 6" X 6" and weighs about 10 pounds. I'd like to lessen the drag on the sled so was thinking of fastening two strips of low-friction materal to the bottom of the sled. Does anyone have a suggestion what I could use? I thought about ball bearings but the design of the sled rules out ball bearings. The sled and H beam are both mild steel. At one time I thought of linear slides but I don't know if they are stout enough.
UHMWPE (aka poor boys PTFE) slippery as snot and cheap as chips
Plastic :eek: WTF I hear you scream, - once ''bedded in'' is very abrasion resistant, ..ever tried grinding PE ?
Oh and don't make the clearances too tight - remember it's a log splitter.
Most of the major woodworking suppliers carry slick strips, thin strips of UHMW Poly with a self adhesive backing. They are meant for facing rip fences, etc.
Easy to replace when worn.
I have built four or five log splitters in my time and I think you might be over thinking this. If you are going to add slick strips then I agree UHMW would be a good choice. However if this splitter has any ass to it at all then I don't think the strips are needed. Just grease up the sled. Greased steel on steel seems to me like it would be more then adequate.
Warring to be written on a splitter.... load holding logs by Sides - Not Ends
One of our Boy Scouts loading wrong had the ram smash his hand.
You could put a hinge on the table so the log once past the blade world slide forward to pile the stack in front.
Hinge table up position in up position when you wish to choose where to stack.
What's to like? Where's the advantage? If you can't afford hydraulics, save your money until you can. I can only imagine what can go wrong. At least with hyd. you can stop the son-of- bitch. How about the big piece of shit that "rubber shoes" was running. 'bout broke his leg. No time to think or move. Did anyone happen to notice they all were splitting nice soft straight grain low BTU garbage. Try it on some real wood! The safest one ever built will still be a scary bastard waiting to unleash it's terror. Too damn scary for me.
Ray, the advantage is speed. With the splitter I'm making the activator handle must be held up for the pinion gear to engage the rack. Plus I have 20 acres of hardwood. I pick trees that aren't a jumble of crotches. When I run into a crotch I noodle it with my chainsaw.
By the way take a look at this impossible limb on one of my trees:
This is on a tree that leaned over some years back. I didn't notice it until I'd cut almost up to it. I'm going to leave it like that.
Sorry about the punctuation. The comma doesn't work on this keyboard. New one on the way.
I have heated with wood for over 40 years and have split hundreds of cords and speed was not a consideration as a tradeoff to safety. Hydraulic splitters ar slower for a reason and with the momentum needed to split red oak is allot different than softwood especially when you hit a knot. I think few people have the reaction time to operate one of those safely. Ray hit the other points on the head.
