Need 3/4" spline shaft
Likes Likes:  0
Results 1 to 12 of 12
    Aug 2003
    Grand Rapids, MI
    8
    Default Need 3/4" spline shaft
    All,
    I find myself in the position of needing a chunk of 3/4" spline shaft for a repair job. I've googled the heck out of this and have so far come up short (story of my life). I bought a hydraulic pump shaft for a Ford tractor that should have been 3/4" parallel 6 spline (SAE). The shaft shows up, made in Turkey, and the splines are all wrong. They should be 3/16" keys and are about 1/32" under. Definition of insanity here, I order another shaft from a supposed different suppler. It did come in a bag with a different name on it, also made in Turkey, and was worse than the first.
    So here's the deal, I find 3/4" couplings all day long in both parallel 6 spline as well as involute 11 spline. Can't seem to find matching shafts. Well, McMaster does have 6 spline for a whopping $250. I find 5/8" and 7/8" spline but not much in the way of 3/4". Case in point, Baum Hydraulics. Scroll to page 18. 3/4" couplers but no shafts. https://www.baumhydraulics.com/images/Catalog/sec-s.pdf
    It seems the world has something against 3/4" spline. I have found numerous threads on several sites about the lack of availability. I could fumble around and machine one but I am trying to avoid that.
    Aaron
    Feb 2014
    Nevada
    7
    Steiner sells shafts with those specs. You may be able to adapt a hydrolic pump shaft for what you need. They fit Fords pattern. Runs 25 to 30 dollars.
    Oct 2005
    17,281
    Aug 2003
    Grand Rapids, MI
    8
    The two Ford shafts that I bought came from two different competitors to Steiner. Maybe Steiner's is from a different source, but I am a bit gun shy.
    One of the G&G shafts is supposedly available through Amazon for a an eye gouging $74 and you'll get it at the end of the month... Maybe.. A bit of a hard pill to swallow given that I can find other size shafts for half the money or even less. It's a non-paying customer (father in law) so I'm trying to stay out of my wallet as much as I can. I'm already deeper than I wanted to be.
    Dec 2008
    Vt USA
    7,405
    931
    2590
    It's here, but be sitting down.
    4 foot length of 3/4 -6 $250
    McMaster-Carr
    It's around, keep looking
    Apr 2018
    3,973
    1794
    Quote Originally Posted by Aaron View Post
    It would only take an hour, maybe two to knock one out. You've probably already spent longer than that looking for one ...
    Aug 2004
    Virginia
    2,454
    179
    971
    Is this a PTO shaft?
    Oct 2005
    17,281
    Your OP stated none to be found.
    So now we find it for you, and you complain on price ?
    Begone to china with you sir !
    Feb 2014
    Nevada
    7
    A great deal of those hydraulic pumps that attach to the pto come new with a very loose fit. Always have. The 6 spline is the lower side of revolution out put from 540 ish to 640. Sometimes even hanging at a angle and securing them with a chain. Especially the sprayer attachments. Are you sure you are not over enginering it?
    Apr 2018
    3,973
    1794
    Thanks, but no thanks ....
  11. #11
    Sep 2005
    Oakland, CA
    2,648
    371
    745
    I think we have a 3/4 6 spline hob if you need a chunk cut. If ya can't find something PM me and I'll check to see what class fit my hob is.
    Dan
  12. #12
    Apr 2012
    Saskatchewan, Canada
    46
    10
    Clearly price is no object for you as it is for the OP. If we all had your money we could burn ours.
