pMetal
- Jul 14, 2014
- United States
I need to drill bolt holes on the ends of 25 foot long I-Beams, and I need the spacing between the holes to be fairly accurate. The spacing between the sets of holes will be around 24 feet apart.
I'm planning to do the drilling on a Bridgeport knee mill (with a DRO), additional supports on each side of the mill to support the overhanging beam.
The mill only has an X-axis travel of 30" or so, which is a far cry from 23 feet.
So I have a few ideas for how to handle this:
A) I could use a tape measure to mark out and establish the origin for the second set of holes. However, I don't know how much I can trust the accuracy of a tape measure over a long distance.
B) I could use a laser measuring device (the type they sell in Home Depot) to establish the origin for the second set of holes. I think I can trust this to be accurate within around 0.1".
C) I could use the mill's travel to "inchworm" the part along, in which I would:
1) Start with the machine table at one extreme of its X travel
2) Move the table (with the workpiece) over 30" and drill a small pilot hole
3) Move the table back to its starting position
4) Slide the part over so that the pilot hole is in range of the spindle
5) Pick up the hole location with a center finder
6) Repeat steps 2-5 until I get within range of the far end of the workpiece and can use the table's normal travel to continue normally.
If I use the inchworm technique and move it 30" each time, I will have to do 10 of the repositioning cycles to make it to the other side.
If I use techniques A or B (which rely on a tape measure or laser measure), I suppose could technically just manually mark out the hole locations and use a magnetic-base drill to make the holes, and it will probably be close to as accurate as using the bridgeport to make the holes.
What do you think will be the most accurate way to get the spacing correct?
Do you have any different suggestions for how to work with parts that are far too long for a mill's travel?
