Need flat eyebolt
Likes Likes:  0
Results 1 to 9 of 9
    Mar 2007
    Longmont, CO
    12
    Default Need flat eyebolt
    Gents,
    I need to find a specific fastener, it's a flat eyebolt, similar to the ones used in aircraft, except completely flat. They look like a threaded rod with one end smashed flat and then drilled through. I've found them on websites from China, but nothing I can order. Any ideas? Here's two examples. Maybe they're called by a different name, I don't know. I need it in an 8-32 thread if possible but maybe could do a 10-32. Okay thanks,
    Flat head bolt
    AN42 - AN46 EYE BOLTS from Aircraft Spruce
    Feb 2009
    New Jersey, USA
    200
    Hi Justin,
    The good news: I found similar things at McMaster-Carr. They're called Flattened-End Hanger Bolts/Screws. See listing halfway down catalog page 3149:
    McMaster-Carr
    The bad news: The smallest size they have is bigger than what you need.
    Knowing what they're called, though, should help you search for sources. You might also call MMC and see if they can get other sizes.
    Hope this helps,
    -Chris
    Mar 2006
    Cape Cod, Massachusetts
    4,658
    1133
    1889
    Reid supply calls them "forged rod ends" but the smallest size they carry is 1/4-20. They may be able to locate smaller ones for you. But now you have a new search term
    Forged Rod Ends [Page Number: 6]
    Apr 2006
    Fort Worth, TX
    1,302
    27
    30
    Jul 2009
    Libertyville, IL
    600
    10
    85
    spade bolts? I have some in 8-32x1. $1.21/100
    Jun 2010
    498
    56
    190
    they look pretty simple, if you only need a few than you could probably make them pretty easily, and in any size or style you wish.
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    226
    Mar 2007
    Longmont, CO
    12
    Gents, thanks for the leads! These are for a production item so I'll need quite a few, hopefully.
    Alex, are you a fasteners dealer? Do you have a website?
    Thanks again guys,
    Justin
    Jul 2005
    2,610
    70
    226
    Here's a thread with the details & link for Alex's site:
    http://www.practicalmachinist.com/vb...s-them-204613/
