Need help changing oil/filter on older Kellogg air compressor - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Sep 2005
    Fayetteville, close to Pond Bank, Pa.
    255
    82
    73
    I don't have a Kellogg but a Quincy 308. The original manual says engine oil is OK if the service is not severe.
    Karl
  2. #22
    Oct 2005
    22,774
    Quote Originally Posted by RJ614 View Post
    ok, got the oil changed today, and will swap the air filter. took 6 quarts! she should be good to go for a while! thanks for the help folks!
    Are you sure that the sump is supposed to hold 6 quarts ?
  3. #23
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,336
    3294
    2084
    6 quarts sounds like a bit much? Oil level should be about midway on the sight glass.
  4. #24
    May 2002
    South Central PA
    14,667
    2874
    4400
    Quote Originally Posted by richard newman View Post
    I have an old Kellogg 5hp, just keeps chugging along. Wondering if anyone has has success reducing noise with bigger or more sophisticated air filters?
    A real long heavy wall pipe helps a lot. Running it out through the wall as well is even better.
  5. #25
    Feb 2011
    3,336
    3294
    2084
    I put one of these on my Quincy compressor, it helped with intake noise compared to the filter that was on it.
    Filter Silencers | Alwitco
  6. #26
    Apr 2004
    Modesto, CA USA
    8,936
    1770
    I put an oil bath air filter on my Quincy from a Gravely tractor engine. I figure any oil carry through is good for the reed valves and piston rings.
    Bill D
  7. #27
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,572
    1882
    2873
    Quote Originally Posted by Bill D View Post
    Bill D
    Not so. The valves can get very hot, and oil vapor can stick to them and turn to carbon.
  8. #28
    Apr 2004
    Modesto, CA USA
    8,936
    1770
    It has been several years and I do not see any drop in the oil level so I do not think there is much if any oil carry through. I do not think oil bath cleaners on cars required topping up. Much cooler operation next to a compressor not under a hood near a hot engine.
    Bill D
  9. #29
    Nov 2002
    Burlington, NJ
    1,440
    42
    176
    6 qts sounds like way to much oil. How much did you drain out? Sometimes the glass window gets dirty enough or the ports in it get clogged so you can't get a good reading. I've never drained 6 qts of oil from a shop compressor like that but I'm used to IR compressors.
    Try dip sticking it from the fill port with a piece of wire. Does the level correspondent with the center of the window?
    Mr Bridgeport
  10. Likes dkmc, richard newman liked this post
  11. #30
    Jul 2006
    Indiana
    573
    300
    100
    ...I'm a mechanically inclined guy..
    ...took 6 quarts! ...
    Huh...Must have filled that crankcase up to the tippy top, eh? That ought to be the last oil change it'll need...
  12. Likes dalmatiangirl61 liked this post
