Need help finding a silver plating vendor - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21
    Jul 2006
    Hillsboro, New Hampshire
    9,964
    2313
    6968
    Quote Originally Posted by gear cutter View Post
    I don't know. But thanks for the info. I am going to bring this to the attestation of the engineer overseeing the project.I still haven't found anyone with tanks big enough to do these.
    If he's a youngster (god, I'm getting old), he may not be familiar with the issue, would be worth doing some searching for "gold plating diffusion copper" to get some background. Like this:
    Gold Plating: Diffusion barrier needed? [heh, I like the "Dilbert tie" of the first answerer].
    Did you contact that company I mentioned that said they handled big parts?
  2. #22
    Nov 2010
    UNITED KINGDOM
    50
    13
    8
    What is brush plated? No one has mentioned that as an option.
    It's used in silversmithing for covering fire stain ( like welding discolouration )and doing internal gold plating for vessels. You use a conductive brush with a silver solution and put the ground on what you're plating.
    I don't know if it is done commercially or just as kits for jewellers, hence the question.
    An introduction to brush plating
