martinberryman
- Feb 18, 2011
- Vancouver, BC
Just received a 1996 Fadal 4020 that was purchased at auction, advertised as having a CAT-40 spindle. We also bought a ton of CAT 40 tooling at the same auction. Working on getting the machine placed, levelled and connected to power, but while moving it I had to remove the pendant. Inside the pendant I found a build sheet that indicates that the spindle was ordered with a BT-40 taper. There is a pull stud placard on the column that shows the dimensions for both Cat-40 and BT-40 pull studs. I have no idea if the spindle is original, or if it has been changed and am trying to figure out if it's BT-40 or CAT-40.
I suppose that once I figure out how to unlock the cover on the toolchanger, I can look at the grippers to see what style they are, but are there features of the drive dogs on the spindle that will tell me the spindle style?
