Need help with manufacturing this prototype
Results 1 to 20 of 20
    May 2014
    United Kingdom
    14
    Default Need help with manufacturing this prototype
    Hey everyone, I am looking to get this prototype made but I am not sure where I can go to get this done in Stainless Steel? I also have a STEP file that shows what it looks like in 3d. The prototype is basically a 7mm rod that is bent on various points to get this shape. Can someone let me know where I can get something like this made?
    Jul 2006
    Hillsboro, New Hampshire
    8,830
    2126
    6116
    I bet one of our UK members could make you a precision bending fixture such that you could bend your own rods. Might be a better option than trying to have the actual part made, then deciding you need alterations to it.
    May 2014
    United Kingdom
    14
    That would be helpful but I am not sure if I can get the measurements to be accurate
    Jul 2006
    8,830
    2126
    6116
    Quote Originally Posted by fatguyslim View Post
    A proper fixture would include length stops and angle stops. Sure, there'll be some trial and error, and you'll have to decide whether your design is set in stone or could change. If set, then let someone else do it. If iterations may be needed, I'd rather have the fixture and be able to try changes myself.
    May 2014
    United Kingdom
    14
    I would definitely prefer making a jig for this, lets hope someone can help me build one.
    Jan 2005
    The Netherlands
    5,958
    287
    1585
    Let someone with a CNC wire bender do it Alterations are easy to make too
    Peter
    Sep 2005
    Oakland, CA
    2,644
    370
    744
    Find a shop that does CNC tube bending.
    Sep 2005
    Dunstable, UK
    36
    23
    Try Wardown Engineering in Dunstable, Beds they should be able to quote for this.
    Tony
  9. Likes Hopefuldave liked this post
  10. #9
    May 2014
    United Kingdom
    14
    Quote Originally Posted by modelmakerblue View Post
    Tony
    Thanks Tony will ring them tomorrow
  11. #10
    Nov 2003
    5,337
    187
    1731
    And without any tolerances on your drawing, no one will know just what accuracy you need. You have designed something, but have not given any thought as to just what those tolerances are, HAVE YOU?
    There is an inverse relationship between tolerance and cost. The smaller the tolerance, the higher the cost. The larger the tolerance, the lower the cost.
    Unless money is no object, then this is a basic part of design work.
    PS: A reasonable inference from your drawing, as it is, would be all linear dimensions are +/-0.1mm and all angular dimensions are +/- 1 degree. But that may or may not work for your part. And do remember that tolerances on multiple dimensions and angles can all add to the maximums or all subtract to the minimums. So three linear dimensions with a 0.1mm tolerance can have an overall +0.3 or -0.3 mm difference. Either of these conditions would be considered to be "in tolerance".
  12. #11
    Jul 2006
    8,830
    2126
    6116
    Tony
    I'd be curious on the one-off cost for this job, or at least a ball-park.
    Also want to see video of the part being bent. Maybe it's the nerd in me, but I find high-speed wire forming fascinating...
  13. #12
    Mar 2019
    Massachusetts
    231
    118
    122
    Custom Wire Forming & Metal Fabrication Companies | Acme Wire Products
    These are my guys for bending wire. They told me they can handle the .375" O.D. Wire/Rod that is the biggest stuff I need to bend.
    Think baskets, shopping carts, etc.
    I am sure you can find someone in the U.K. that does this. It is its own industry and they have machines built for this kind of work.
    Try youtube for examples
  14. #13
    May 2014
    United Kingdom
    14
    Quote Originally Posted by EPAIII View Post
    I see what you mean and will try and work out my tolerances
  15. #14
    May 2014
    United Kingdom
    14
    Is it possible to make this prototype using metal casting? Say if I get this 3d printed and then send the printed part to a casting company or someone in here who specialises in stainless steel casting. Will that work with something with such a thin diameter?
  16. #15
    Jan 2005
    The Netherlands
    5,958
    287
    1585
    If I had to do a one or 2 off I would bend them with a torch and make some steel blocks with the right shape to bend then on
    Start with the 43mm U shape Take a piece of stock 43 -7 = 36mm thick and use it as a simple jig Some radius at the end and bend the wire over heating it with a torch
    Then a simple jig for each bend
    Can be accurate
    Peter
  17. Likes michiganbuck liked this post
  18. #16
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,145
    450
    1076
    I haven't totally thought thru all of the steps but I'm guessing a Diacro bender could make that fairly easily.
    I'd budget about 6pcs worth of length of the virgin rod if it has to be perfect. There would be a little trial-and-error in setting up length stops or measurements to get it right, and possibly dealing with interferences as the part is progressively formed and its not a simple flat wire anymore.
    Helpful to have access to a lathe to make the bender tooling pins.
  19. #17
    Feb 2013
    Madison, WI
    1,079
    1157
    694
    I agree. I could watch those auto bending videos all day.
  20. #18
    Jul 2006
    8,830
    2126
    6116
    Quote Originally Posted by AARONT View Post
    Heh - someone needs to do a study on why this happens. Are bender fanatics easily hypnotized?
  21. #19
    Jul 2006
    8,830
    2126
    6116
    This sounds really expensive relative to the basic shape and requirements. I think Peter has a good idea, but you might have to make some of the bending forms as "built up" segments, so you could separate them after the forming. This has an additional benefit of being able to shim the segments to correct length errors.
  22. #20
    Jan 2005
    The Netherlands
    5,958
    287
    1585
    I immagened a seperate jig for every bend The jig has to possition or clamp that part of the product that is previous bend
    peter
