Mikel Levy
- Oct 19, 2009
- Seattle
I acquired this Sjogren collet chuck, model 2A-D3, and took it apart while looking into some runout issues. The first photo shows the front half of the chuck with the rear (spindle side) half in the background. The bore of the center gear is threaded to receive the 2J collet. As the center gear rotates and pulls the collet in, the opposite face of the center gear hub, as I surmise, is supposed to contact a thrust washer (tinted blue in the second photo) which in turn contacts a thrust bearing. However, in my unit the back end of the hardened spindle sleeve (tinted in purple) projects farther into the chuck body than the thrust washer/thrust bearing assembly by about .020" (1/2 mm), so that the hub of the center gear rubs against the narrow back face of the spindle sleeve instead, rendering the thrust bearing unused. It appears to me that there is a missing washer or spacer that fits between the center gear and the thrust washer. It's odd, since a thicker thrust washer would obviate the need for an additional part. It makes me think there's something missing in my understanding of how this contraption works. It's hard to find accurate info on this as there seems to be a large number of models of this chuck, with the innards arranged somewhat differently for each model. Any definitive advice on this would be much appreciated.
Mike
