Hi Everyone,
I’m looking to find a tapered bore bushing for a project I’m working on and can’t seem to find any information. I figured maybe someone here can help me get it figured out.
Long story short I have a small engine crankshaft with a tapered end on it. i need a bushing with the same taper to sit on the end to adapt a different flywheel by means of bolting on.
My measurements are:
Large dia: (closer to engine block) ~.892”
Smaller dia: (end of crankshaft) ~.708
Length of taper: ~1.125”
I’m looking for a bushing similar to this: Tapered and QD Bushings - Bushings - Grainger Industrial Supply
Basically what I want to do is bore the new flywheel and bolt the bushing onto said flywheel that will fit my crankshafts taper properly.
I believe this makes sense but maybe I’m looking in the wrong place for a “mount” or bushing.
Thanks!
Thanks!
