Hi All!
My first post here. I've come across this forum a while back while searching for a horizontal mill and relevant information. This is a great site! I ended up getting a US Machine Tool Co mill and have been using it for a while now. Works great but I need some help. The previous owner didn't have the handles/wheels for it and I've been searching for some but can't find anything that will work. Could be that I'm not looking in the right place either. They need to mount to 3/8" square post. The handle in the middle would also need an extension so the table doesn't interfere with it's use. I've attached a picture as well.
The other area I need some help with is a vibration. When I was putting on the large belt cover I loosened the bolts on the motor plate. I must have not got it back in the right spot since now there is a vibration when the mill is running. What is the best way to align the belt and try to eliminate the vibration? It's driving me nuts. I've moved the motor around on the plate a few times but nothing seems to work. I've also attached a picture of the motor.
Thanks in advance.
Brandon
I'm not sure why the pictures are sideways either. They aren't that way on my computer.
Thanks in advance.
Brandon
